head porting suggestion
I think most of my problem was in the tune, and my restricted exhaust. Tune is better today, and ride the truck sideways to about 60mph tonite..lol. I want going into pe mode and was running too lean.
Need to get some better heads too... it never ends...
Unless you are locking the converter then yes you may notice some slipping. I would guess that being an autozone stall it's not the very best quality and naturally its not overly efficient. If I remember correctly converter efficiency was a huge factor for blown06. In high powered setups it becomes increasingly more important. Think about it this way you wouldn't use a stock clutch built for 250hp 3000lbs car in a 600hp 5000lbs build. So why would you use a stall built for a 150hp trailblazer in a 400+hp full size. Swapping to a proper stall built for your setup will help dramatically.
GrooveCityZ71
08-31-2015 12:05 PM
bbowerman
07-26-2015 10:57 PM
