Gen IV 6.0 build ?s and info
#21
If worse comes to worse and you need to open that journal up to the size of an outside bearing I think I have a new one in the box, you can have it
#22
I'm in Clayton NC
I've been told about a few local but one that seems to be popular looks like a bomb went off in it and is very unorganized. Another was recommended by Rick Crawford (Rick Crawford Racing) but still 2 hours away.
That is good to know, thanks for the info.
Thank you for the offer as well, I appreciate it and will keep you in mind.
I'm hoping to be able to get some time off within the next couple of weeks to make the trip to the shop.
I've been trolling the net looking for parts. I think I'm a little anxious hah.
Should I wait until I visit the shop to get his opinion before buying anything?
I like the 6.2 idea with LS3 parts.
Thanks again guys
I'm not sure if this is possible without special equipment. The cam journals on my gen IV were different sizes. The middle was the smallest, next two out were slightly bigger, and end bearings were the biggest. I am new to this, but I believe they did this for the installation process. Maybe someone with more knowledge can shed some light on this.
Thanks again guys
#23
I think the best machine shops honestly look like a bomb went off but the guy running it could walk over and pick up exactly what it is he or you are looking for the first time.... Hell the head shop in va beach you have to step over stuff to get to the fromt counter but they do awesome work!!!
#25
I'm new to all this, learning as I go.
#26
Im not a machinist, but as far as i know the cam gets smaller from front to rear at least as far as the bearing lands go, however the way the back of the block is open on the ls engines it may be possible the outer diameter could be same front and rear, never paid that mych attention to it, havent oersonally had to deal witha spun cam bearing yet....
#27
Custm2500's Rude Friend
The only way would be to line bore, How ever there is no Repair bearings available to do this.
If the journals are still good, you can clean them and install new bearings. As long as they go in tight you should be fine. Some shops will use a slip fit adhesive when doing this for added insurance. It's usually best to let someone with experience do this. Its usually around $25 for cam bearing set and approx $50 in labor. My engine shop usually keeps a cam core in stock to use to insure the cam spins freely after the new bearings are installed. If they are working on something special they will usually request you bring the cam in to insure it fits and spins properly after they install the new bearings.
In My case, I gave them a good used cam core to work with for the LS engines.
#29
This service can not be done on LS block's since they don't use a similar sized cam bearings.
Well, now I'm not feeling so good about this now, haha.
I by no means have any experience with and am learning as I go. I will most definitely leave this work up to the machinist.
Unfortunately, the only cam I have is the one that came out of the motor. Will that work?
I'm going to call him during the week and discuss this with him.
Thanks again 1Fast, I appreciate it.
