Gen IV 5.3l Silverado turbo kit questions
#21
They are actually bout 5mm taller than stock truck ones so all i dd was space the rails up with a thick washer....and they are ev14 so ya needs pigtails( which are like$8 ea) but still cheaper than the plug and play by over $100
#22
Restricted
For the 07 and up trucks, except the classic, the 48mm standard length EV14 is a direct plug and play, because it uses the USCAR connection. If you have a pre-07 you're going to have to run pigtails. The EV14 injectors come in three different lengths compact, standard, and long. The standard is what you want for the 07+ truck. Also the number I posted earlier sells them for a killer deal as well, $270 brand new, 60# at 3bar, and that's shipped. Hope this helps you out some!
#25
Registered User
questions?
Anyways I see you built one for under 4000 dollars. Was it a kit or pieced together?
Thanks for any help you can be
New-2
#26
Can I call your buddy? I'm swapping my 96 impala with a 2000 LM7 in the Chicagoland area
FlowmasterMufflers
07-17-2015 03:26 PM
