Front wheel hub removal tool or socket size?
Old 08-14-2009, 10:21 PM
SUPERCHARGE's Avatar
Originally Posted by 006rcsb
borrowed from silverado ss . com, mr.p's write up on lowering an ss with spindles, which is the same for 4x4.
http://www.silveradoss.com/forums/in...howtopic=19941
torque specs are listed here also
http://www.silveradoss.com/forums/in...04&mode=linear
Aw crap!, so this guy's using a 36 mm socket? WTF man. Am I going to have to go out there and measure the damned thing? I use a big-*** torque wrench that goes on sale oocaionaly for 55$ (regular 130)as a breaker because last time I spent 30$ on a big nut breaker, the damned thing bent on the first application and broke on the fourth. Also need to figure out how many pounds I'm suppose to use to but the axle nut back on.
Judging by how much force he was applying in that pic, looks like at lease 150ft/lb.
Old 08-15-2009, 10:40 AM
006rcsb's Avatar
I gave you a link to a thread for the torque specs, it was the last link in my post... hell, you even quoted it in your last post...lol. Anyway yeah its a 36mm socket, I used a 36 on mine when I put on my mcgaughy's spindles on my 06 and I don't think they changed the nut size between years. I got the socket from the autozone by my house. As far as it goes for having to use a breaker bar, mine weren't on all that tight.
And I guess I'll post the torque specs from zippy's posted specs on silveradoss on here for easier finding...
1. Steering knuckle to spindle bolt-------------------133 lb ft
2.CV joint to front axle bolts-------------------------58 lb ft
3. Ball Joints----------------------------------------74 lb ft (lower) 37 lb ft (upper)
4. Front spindle nut(the big 36MM one).--------------177 lb ft
Old 08-15-2009, 11:53 AM
phasemaster1's Avatar
Great info thanks!
Old 08-15-2009, 12:09 PM
black04's Avatar
I used that same write up when i did my spindles on my 04. It was a 36mm. Its actually a little bigger than a 35 but the 36 works fine.
Old 08-15-2009, 12:19 PM
droppedchev's Avatar
yeah the hub is a bitch to get out mine was rusted in there i had to beat it for 2 hours with a sledge hammer
Old 08-15-2009, 12:25 PM
black04's Avatar
unless your replacing it i wouldnt beat it with a sledge. Rubber mallet was fine for me.
Old 08-16-2009, 09:45 AM
Thanks, great info. I now have a 36mm axle nut remover reserved at Canadian tire for 15$. Their rent price is 5$ plus deposit. The fuel to bring it back isn't even worth it. I measured the bolt size and it was definitely close to 36 mm, far from 32mm.
chopperloco
07-10-2016 10:45 PM
maxspeed05V
09-09-2015 11:36 AM
FlowmasterMufflers
07-30-2015 05:03 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: Front wheel hub removal tool or socket size?
