Forged 408. Which Heads ?
I bought a brand new forged 408 short block for my 2000 extcab. I have a set of 215 trick flow heads. I'm thinking they are too small. I'm going to run a Comp Cam 239/242 623/610 112. Which heads would you recommend? It will also have all the bolt ons. Thanks. Mike
for a 408 with those heads I would probably go a tad smaller. Look for like a 6300-6400 shift thats just brawny as hell. That thing will make power everywhere.
The cam I'd run would look like this (assuming its a toy and not a DD):
231/234 113+3 LSL intake and LXL exhaust.
Do the heads have bronze rockers? If they do make sure you are using a roller rocker and not the stock style... you will kill the valve guides with stock style.
Sounds good! Should be a power house. Maybe a tad more exhaust bias than the heads need, but with less advance the valve timing works out very well. It literally splits overlap exactly over TDC. I like it. I'd bet power comes on REALLY strong and it will be happy with a 6200 RPM shift point. It'll take more but on the street you wont need to ring its neck to get good performance out of it. At the track you could set them to 6400-6500 I bet.
