fixing collector exhaust leak
#21
Welcome aboard
I haven't had any issues like the op. Not sure how he resolved.
Typically, when I weld flanges/v-bands I'll bolt/clamp them together quite snug to keep a flat tight surface and not remove the bolts/clamps until cool. If I am only welding one side of a 3 bolt flange I will make a jig to bolt it to a solid surface, then weld and of course wait until cool to remove.
#22
Welcome aboard
So wat u think about bracket?
#24
A little more then a month ago, I had some new flanges welded on mine so I could pull the ypipe if needed.
The exhaust shop made me new flanges from scratch. The trick is the flange needs to be thick. I was concerned about them leaking and he assured me they would not leak. To date, I have no issues with them.
When he built them, he welded the inside of the flange/tubing. Not sure if that makes a difference.
Some of the mass produced stuff uses thin flange material and they warp and blow the gasket.
If I ever have an issue, I'm putting ball and sockets on them.
#25
#26
I weld the insides as well. It basically gives you twice the coverage and ensures it will not leak.
I do like ball and socket joints.
I'll check it out
JFortner5
08-20-2015 06:13 PM
