Exhaust manifold stud - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 03-06-2008, 08:52 PM   #1
Default Exhaust manifold stud
Well today trying to take off my stock y pipe i rounded off 2 nuts on the manifold side. Im at work right now and was gonna grab a small burr to cut the nuts off, anyone know the thread size and pitch on the stud so i can chase them if i burr too deep?
lpguy is offline   Reply With Quote
Old 03-06-2008, 09:36 PM   #2
nonnieselman's Avatar
i believe they are just a 3/8" ... i got some from my local parts store and they were just GM exhaust studs or something like that..
nonnieselman is offline   Reply With Quote
Old 03-07-2008, 10:33 AM   #3
Truck Sponsor
Quote:
I thinks its metric 8MM..take an extra nut with your to work to confirm. Sears has these nifty rounded nut remove tools. They have curved teith cut back wards so when you are loosening the dig in harder..
Great care when cutting off a nut not to damage the thread or cut to deep into the studd,, it will weeken it.
TrickTurbo is online now   Reply With Quote
Old 03-07-2008, 02:05 PM   #4
damn these seem like they are made out of aluminum... tried those rounded nut tools only rounded them some more...
Old 03-08-2008, 02:13 AM   #5
can anyone tell me if these studs are pressed in the manifold? Any advice on getting them out if they are? I should be able to get replacements at autozone or something right?
Old 03-08-2008, 05:55 AM   #6
How do I change this text
Wilde Racing's Avatar
They are not pressed in, I would recomend heating the manifold around the stud with a torch. You could also try welding a nut on what is left of the stud...
Wilde Racing is offline   Reply With Quote
Old 03-08-2008, 08:07 PM   #7
High on diesel fumes
thunder550's Avatar
I had a bolt that got stuck last week. Kyle took a torch and chopped off the head and all was good. He even got the broken studs out, but I don't know how
thunder550 is offline   Reply With Quote
Old 03-08-2008, 08:11 PM   #8
03sierraslt's Avatar
I had the same thing happen on my old truck, I just cut it off and removed the manifold. Then drilled out the old broken stud and installed a bolt in its place. I personally hate studs in exhaust setups. With a bolt if it ever strips or gets siezed in place I just cut it off and install a new one. JMO. Its a little tricky to drill out the manifold stud, just start small then work up if you are going to do it.
Anytime I know I am going to be unbolting anything in the exhaust I spray the bolts etc. down with Aero Kroil or PB blaster ahead of time and let it soak in. This has worked great to do it that way.
03sierraslt is offline   Reply With Quote
Old 03-08-2008, 08:33 PM   #9
Yah i soaked em in pb blaster before i started... just didnt do the trick... I ended up cutting off the flange part of the nut and then it came off without screwing up the stud... im only getting to work on it a little each day. I get tomorrow off so ill have alot of progress and ill post some pics of the new trick kit...
Old 03-10-2008, 06:55 PM   #10
Any updates, what did you figure out with the manifold stud?
Thread Thread Starter Forum Replies Last Post
Garage Sale jfuegner GM Parts Classifieds 10 12-22-2016 04:47 PM
Stainless Works 2006-2009 Trailblazer SS Headers & Exhaust Stainless Works TrailBlazer SS 6 04-10-2016 05:34 PM
FS: Duramax swapped RCSB 1500 4x4 thunder550 Trucks and SUV Classifieds 9 10-08-2015 05:53 PM
F/S: taylor 8mm wires, stock LS2 cam, tbss converter , manifolds maxspeed05V GM Parts Classifieds 0 08-17-2015 09:41 PM
Tags
2004, 4240, bolts, broken, duramax, exhaust, gm, i5, mac, manifold, pitch, rounded, silverado, size, stud, thread
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
