engine noise=lifter or piston slap??
Old 04-30-2011, 05:43 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by smokeshow
*half
Originally Posted by AKlowriderZ71
Backwards Billy. Camshaft speed is 1/2 of crankshaft speed. Faster noise would be crankshaft speed, slower noise would be cam/valvetrain noise.
Whoops, screwed that up again (meaning that I've said the same thing before lol )...I knew what I meant lol. Twice, half, what's the difference But yep, crank turns twice for every one full turn of the cam which can be seen by the larger cam gear and smaller crank gear duh. Edited my post so's not to cause any confusion Thanks fellas
And yes, Roger explained why shorting the cylinder will reveal a rod knock, since there is no explosion to push down on the piston and rod, they're just along for the ride
Old 04-30-2011, 05:48 PM
Mang213's Avatar
No. That doesn't make any sense at all.
If you take away the spark, the air/fuel mixture does not ignite. It just goes thru the cylinder. There is no explosion to force the piston back down, there is no load on that cylinder.
And, only one cylinder fires at a time.
Trust me, this does work. I've been doing this stuff for a long time.
I think what he was trying to say was that when the one cylinder is in it's compression stroke, the opposing cylinder is firing it's plug, and putting enough of a load (a small load, but a load nonetheless) on the compression cylinder to help generate the culprit noise. There isn't any explosion to force the one piston down, but there is still a small amount of load just from compressing the air/fuel mixture. Im not saying you're wrong by any means, just trying to clear up what the other poster was getting at
Old 04-30-2011, 05:52 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Regardless of what he was trying to say, it's untrue. The method works, and always has.
Old 04-30-2011, 05:58 PM
PT's Slowest Truck
budhayes3's Avatar
I can vouch for this as I've used this method many times (hence why I posted it lol).
Old 04-30-2011, 06:05 PM
Mang213's Avatar
Like I said before, I didn't say you were wrong, but I understand why he's asking the question. There will still be a bit of load on the nonfiring cylinder due to compression, and maybe it would be enough to still allow for the piston or rod to make the noise. Perhaps a more thorough way of testing each cylinder would be to actually pull a plug and relieve all the compression pressure, instead of just pulling a wire. Just a thought. Hopefully no one is offended by my useless advice or thoughts. Sounds like good theory to me, if used in conjunction with the process you already outlined
Old 05-01-2011, 10:38 AM
getchusum99's Avatar
its the same exact sound it made on cold startup,in the past. but that would quickly go away, ive heard this same sound on several motors just like mine, on startup atleast. but they go away eventually. it seems like its going half the speed of the rpms, which would be a lifter ,right? its definately on bank 2- drivers side.
Old 05-01-2011, 11:35 AM
PT's Slowest Truck
budhayes3's Avatar
Yes, half the speed of the crank would be valvetrain related (not twice like I mis-posted before lol)
Old 05-01-2011, 12:32 PM
LowBlack99's Avatar
Not doubting what your saying, just trying to understand it a little better as I also have been doing this a long time and have never used this method of diagnosis? What im trying to understand is this, If you have a bottom end problem ie, rod bearing, wrist pin etc... how would removing combustion change anything since the affected cylinder would still be moving on the force generated by the other cylinders? Every time combustion occurs it puts force on not only the cylinder it occurs in but also on the cylinder its opposite of on the crankshaft. Like I said, just trying to understand a little better by asking?
Old 05-01-2011, 01:19 PM
PT's Slowest Truck
budhayes3's Avatar
The force of combustion is much greater than the force of compression, the explosion on top of the piston forces the piston/rod assy down, and if you have a bad rod bearing, you will heard a very loud knock. Once you remove the explosion, the piston is no longer being forced down but is just freewheeling on the crank, and the rod knock will be significantly quieter or totally disappear.
Now on a piston slap, which is the piston rocking in the cylinder, it will make noise no matter what, like you're thinking about with the rod knock. We recently had an older IS300 with a piston slap that was confusing the tech that was working on it. Once we determined it was bottom end, I had the tech disconnect the coils one at a time and the noise remained. I told him "piston slap" and he was skeptical (not a common Lexus problem). We sent the shortblock to the machine shop who freshened it up, replaced the piston and pin, and now all is well.
We've been using this method in the shops that I've worked in since day 1, it's common practice, and may even be a question on the A1 ASE test IIRC...I know that it has been outlined in the Engine Repair Study Guides.
Know somebody with a rod knock? Try it out for yourself
Old 05-01-2011, 10:57 PM
sooooo.. do u guys think using some thicker oil will help? ive got 3 gallons of mobil delvac 15w40.
Quick Reply: engine noise=lifter or piston slap??
