Drone and Resonator Placement
What is the best location for a resonator to reduce drone? I am in the process of doing a new exhaust system, at the moment I am looking at doing Dual 3 from my collectors to my muffler, muffler will be a Magnaflow Dual 3" in/single 4" out. My options are to run two smaller magnaflow bullet style mufflers before the large case one or run one large diesel style muffler after the axle before it exits. Which do you think would be the most effective? Naturally I have to get it made before I know how loud it will be but I suspect it will be a bit much for my tastes.
I put new headers and mid pipes on so now I gotta finish out the rest, trying to up the flow a little bit.
Formerly ScreamingL
if you are going to run a dual into single setup then i would place the 2nd muffler after the magnaflow
my crewcab was dual 2.5 into a single 4", it had rasp and was horrible with a dynomax ultra flow muffler, I added a flowmaster and drone went away and rasp is gone. exhaust quieted down alot at cruising but WOT its still loud but has a clean sound
