Do new lifters need to soak in oil for awhile? - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 06-28-2011, 09:31 PM   #1
Resident Retard
BlackGMC's Avatar
Default Do new lifters need to soak in oil for awhile?
I think i have read it somewhere to soad new lifters in oil prior to installation. Is that true or recommended?
BlackGMC is offline   Reply With Quote
Old 06-28-2011, 09:33 PM   #2
charcoal03silvy's Avatar
I've read the same thing. Let em soak
charcoal03silvy is offline   Reply With Quote
Old 06-28-2011, 09:35 PM   #3
scooter k's Avatar
Helps get the air out of them by soaking plus lubricating them for installation.
scooter k is offline   Reply With Quote
Old 06-28-2011, 09:36 PM   #4
only soaking them wont do much. submerse them in oil and do you best to "pump" them up with your fingers and get some air out to kinda prime them.
pwerlineman is offline   Reply With Quote
Old 06-28-2011, 09:38 PM   #5
11 sec. Truck Mod
TIM Z's Avatar
I would and did mine for piece of mind.
Just buy a jug of like super tech oil from wally world, its cheap and will be fine for the lifters and the cam install lube.
TIM Z is offline   Reply With Quote
Old 06-28-2011, 09:48 PM   #6
Coban's Avatar
It's thought that soaking them overnight will help to fill and prime them and lessen the chances of them collapsing.
I recommend to do it and also make sure you tighten your rockers down in the correct order to further lessen the chances of collapse.
Coban is offline   Reply With Quote
Old 06-28-2011, 10:15 PM   #7
f4tal's Avatar
I always soaked my lifters?! Idk if its protocal but it doesn't hurt. Peace of mind IMO
f4tal is offline   Reply With Quote
Old 06-28-2011, 10:21 PM   #8
bigboy576103's Avatar
Ok rookie Jk Bro....
Do it, it lubricates the bearings and internals so that when u first initially start the engine its not running dry but when you torque down the rockers it will squeeze the oil out of the plunger but the bearings and internals will still be lubbed up and ready to rock... I would suggest using something thick and sticky like 15-40
bigboy576103 is offline   Reply With Quote
Old 06-29-2011, 01:05 AM   #9
11 Second Hall Moniter
AKlowriderZ71's Avatar
I always do it.
AKlowriderZ71 is offline   Reply With Quote
Old 06-29-2011, 01:14 AM   #10
KY_BOB's Avatar
Quote:
That's what I was taught to do about 20 years ago and still do. They may be roller lifters now instead of the old flat tappet ones then but they are still hydraulic (unless your going VERY extreme). Air and hydraulics don't work together.
KY_BOB is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2009 turbo Silverado Texas5.3_1251 Trucks and SUV Classifieds 12 03-05-2016 09:10 PM
Old member, new truck Dezmo New Members 4 09-09-2015 03:09 AM
L33 engine Brandonlflr12 GM Engine & Exhaust Performance 5 09-08-2015 10:01 PM
Lurker that followed directions. 11MPG New Members 6 09-08-2015 05:52 AM
Mild cam??? Cowboy Tom GM Engine & Exhaust Performance 6 09-05-2015 05:29 PM
Tags
53, break, chevy, ford, in, injectors, installation, lifter, lifters, long, oil, oiled, prelube, process, soak
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
