Difference between LS1 and LS6?
Old 02-22-2012, 09:25 PM
TXSZ66AVLANCHE's Avatar
Yah I am a genius, don't *** with me
Old 02-24-2012, 11:25 PM
ls1ow's Avatar
the LS6 also had a upgraded oil pump as well as rod bolts
Old 02-25-2012, 05:11 AM
No it does not...LS6 uses the same oil pump as any other gen3 engine, rod bolt also. People get scammed all the time on "LS6 Oil Pumps" and other LS6 parts
2004 Corvette Z06 vin# 45122648
12586665 Oil Pump
12607475 Connecting Rod
11610057 Bolt, Connecting Rod
10238852 Rod, Valve Push
89017582 Piston
2004 Corvette vin# 45121945
12586665 Oil Pump
89017581 Piston
Old 02-25-2012, 07:42 PM
ls1ow's Avatar
12586665 Oil Pump
89017582 Piston
12586665 Oil Pump
89017581 Piston
what are they compared to a 2000 Camaro?
if i remember correctly the pump changed on the 01 LS6, and then was used on all LS1 motors after 2002, just like the intake etc, and i thought the same on the rod bolt, but i could be wrong, would like to know just for my knowledge
Old 02-26-2012, 03:56 PM
dmelvin's Avatar
12586665 Oil Pump
89017582 Piston
12586665 Oil Pump
89017581 Piston
I was planning on putting a Melling "Ported LS6" oil pump on this, basically just because. Should I still go this route given the information. I know TSP says they see 10 more pounds with this pump versus a stock pump.
Old 02-26-2012, 08:23 PM
1999 Camaro vin# X2119312
12586665 Oil Pump
12568734 Connecting Rod (1st design Gen3 rod)
88984345 Piston (1st design non-coated piston skirt)
Old 02-26-2012, 08:27 PM
Im planning on using the plain ole Melling oil pump, or maybe the high volume standard pressure pump if I see a deal on Amazon.
ls1ow's Avatar
cool, thanks for the info always cool to learn something new
Old 02-26-2012, 09:35 PM
dmelvin's Avatar
If you find that deal. Shoot me a PM
Old 02-26-2012, 09:46 PM
jrmchevyman's Avatar
I found several melling on ebay for around $96 + shipping. It has the P/N 10295. Melling also has another pump and the P/N is 10296 and is a little more money.
The p/n 10295 is what most would prob go with.
Quick Reply: Difference between LS1 and LS6?
