Critique this setup
Old 11-28-2016, 06:14 PM
GM1697's Avatar
1800-2000 around same tightness than stock... youll wanna go loose with that. a 3k atleast.
Old 11-28-2016, 06:28 PM
Able2007's Avatar
Originally Posted by madmann26
What are you looking for in the cam?
Something torquey down low with a decent lope at idle. BTR recommended the stage 2 for the specs I listed.
Old 11-29-2016, 06:01 AM
madmann26's Avatar
The stage 3 cam they have is similar to the one I had and it was a torque monster with the 3200 stall. It was fun.
You can't go wrong with what they recommended. It'll be a noticeable bump.
Old 11-29-2016, 01:27 PM
Able2007's Avatar
I'm a little hesitant to go that big on a stall. Never driven a vehicle with one and not sure what happens when I hook the trailer up and head to the mountains.
Old 11-29-2016, 01:43 PM
madmann26's Avatar
Not much happens. In everyday driving, the converter is a little looser, which means it revs easier/faster.
It's when you stomp the gas is when it "stalls" or flashes to 3200 before it moves.
If anything, it'll help towing in everyday driving.
Old 11-29-2016, 01:55 PM
Able2007's Avatar
Nice! Thanks
Old 12-16-2016, 03:52 PM
Able2007's Avatar
So I think I've zeroed in on the tsp 212/218 with a 112lsa. Only question is what would be the advantage/disadvantage with the .550 lift vs. the .600 lift?
Old 12-17-2016, 07:42 AM
madmann26's Avatar
Advantage is that it'll make a little more power.
Disadvantage is that you'll spend more on springs and you'll most likely have to run a different pushrod.
Old 12-17-2016, 11:57 AM
Able2007's Avatar
Ok well I was considering sending the heads to PRC for the stage 2.5 and have them milled. Push rods were already a consideration. They offer the pac 1218's with .600 lift and tsp .660 dual springs pretty reasonable with the job.
Old 12-18-2016, 04:23 PM
10 Second Club
Do they offer that cam on a 110 LSA?
