Castech heads casting problem years? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 01-20-2012, 01:27 PM   #1
MASS seller approved
Default Castech heads casting problem years?
Does anyone know what years the castings were a problem with the heads that have the castech emblem. Also which model heads where affected. Thanx in advance
Petey62782 is offline   Reply With Quote
Old 01-20-2012, 02:12 PM   #2
Custm2500's Rude Friend
1FastBrick's Avatar
This issue was mainley on the 706 heads found on the 4.8/5.3L from something like 2001-2006 There is a GM TSB floating around some were. I have seen a few issues with brand new 243 heads that broke the rocker stand casting off but because theywere not used in a production enviornment it's hard to say why the castings failed.
Models affected:
2004-2006 Buick Rainier
2001-2006 Cadillac Escalade Models
2001-2006 Chevrolet Avalanche, Blazer, Silverado, Suburban, Tahoe, TrailBlazer Models
2001-2006 GMC Envoy, Jimmy, Sierra, Yukon Models
2001-2004 Oldsmobile Bravada
2005-2006 Saab 9-7X
with 4.8L or 5.3L VORTECŪ GEN III, GEN IV V8 Engine (VINs V, T, M, B, Z -- RPOs LR4, LM7, LH6, L33, L59)
1FastBrick is offline   Reply With Quote
Old 01-20-2012, 02:15 PM   #3
1FastBrick's Avatar
found the TSB with a google search.
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
Old 01-20-2012, 02:34 PM   #4
Thanx guys I picked up a set of 243 off a trailblazer ss so I wasn't sure but I will pay close attention to the rocker arm mount
Old 01-20-2012, 02:39 PM   #5
1FastBrick's Avatar
You will probally be ok with the castings as long as the engine was taken care of. The few failures I have seen were on engines that had aftermarket cams installed or the heads were ported. The were 2 or 3 that I heard about on low milage Stock Corvettes under warrenty but It's tough to say why they failed with out actaully doing analyiss on the broken parts. Probally more of a fluke then any thing.... It happens.
Old 01-20-2012, 03:18 PM   #6
Thanx again 1fastbrick . I appreciate your fast replies.
Old 01-20-2012, 04:29 PM   #7
1FastBrick's Avatar
Quote:
Your welcome!
Old 04-22-2012, 09:32 PM   #8
KB1
Registered User
Default Castech Heads
I to am having the problem with loss of coolant, as I am now reading about in 3 different web site. My question is: I bought my truck new. Took good care of it. at 120,000 miles cam went bad so dealer replace lifters, valves, etc. (sept 2010) Half my cost, Half Chev. Left dealer in Billings Montana in route to Dayton, Oh, 1700 mi. 300 miles out truck started using oil. lots! Back to dealer in Nov. 2010. The dealer replaced my original engine with a GM "Good will" engine. 9 months later, the loss of coolant became apparent. My question is, Other web sites say the heads are a known manufactuing problem from 2001 to 2007. I need to know how to read the casting stamp date on the head. Could GM actually be adding insult to injury by using these old bad heads in their reman. engines and SELLING THEM AGAIN.
KB1 is offline   Reply With Quote
Old 04-23-2012, 12:41 AM   #9
chevymec's Avatar
Quote:
Read the 3rd post in this thread and it will answer your question with the link.
chevymec is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Looking into a newer truck with 4wd cams 98 silverado GMT 900 Trucks General Discussion 7 07-31-2015 08:36 AM
4L70E shift problems ferrellrooster GM Drivetrain & Suspension 5 07-13-2015 10:53 AM
LQ9 Bolt ons (ls6 heads?) Aboss GM Engine & Exhaust Performance 7 07-09-2015 11:28 AM
Tags
2005, 53, avalanche, castech, casting, chevrolet, chevy, head, heads, installed, problem, problems, vin, warranty, years
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
