Can i use LS2 cam in my LMG 5.3L engine ?
I have the cam in my garage already, and thought of buying a DOD delete kit, and LS6 springs, not looking for a big performance increase, mainly I want to get rid of the DOD garbage, I have DOD disabled in my tune.
What else would I need to buy assuming I can run the LS2 cam ?
Do I also need to do a VVT delete ?
Thanks in advance.
Thanks in advance.
Nice, thanks a lot dude, this is the list of parts I have in mind
Do you foresee anything else i'll need ?
DOD Delete
(1) 28-12557840 - GM LS1/LS6 Balancer Pulley Bolt
(1) 28-12588670 - GM LS2 Chain Dampener
(2) 28-12589226 - GM 5.3L Multi-Layer Steel Head Gasket
(2) 28-17800568 - GM Cylinder Head Bolts for LS2 and 2004+ New Style LS1 Engine Blocks
(1) 28-12599296 - GM LS3 Valley Cover
(1) 28-12594779 - GM LS7 PCV Tube U Shape
(1) 28-12579145 - GM Rear Passenger Side Rocker Cover Cap
(4) 28-12595365 - GM LS2 Lifter Tray
(16) 28-25341990 - GM LS7 Lifter
(1) 202-C5171 - Cometic LSx Timing Cover Gasket with Front Seal
(1) 202-C5174 - Cometic LSx Water Pump Gasket Set, Includes 2 gaskets
VVT Delete
LS3 Front Timing Cover with Cam Position Sensor
3-Bolt Cam Gear (4X)
ARP Camshaft Bolts
Pickup Oring
28-12584922 - GM Oil Pump O-Ring for 99+ Silverado
Valve Springs
28-12499224 - LS6 Valve springs
LS2 Cam (got it)
204/211 .525/.525 117.5LSA
DOD Delete
VVT Delete
ARP Camshaft Bolts
Pickup Oring
Valve Springs
LS2 Cam (got it)
5.3lSilverado
25
08-29-2016 12:48 AM
07NBSChevy
20
07-08-2015 07:27 PM
