cam swap on my 92 gmc tbi
Old 03-28-2012, 06:22 PM
  #21
DR132's Avatar
Good decision.
Old 03-28-2012, 06:42 PM
  #22
zero2sixT's Avatar
Originally Posted by matt92extcab
Im just gonna save my money and do a 5.3 or 6.0 swap. In Cali you can get it bar'd by a smog referee so it will pass emissions
You can never go wrong with a 6.0. That being said, on a budget, there are some pretty cheap mods you can do to the tbi to make it run fairly respectable. Unlike the LS engines, there are a lot of bolt ons that free up a good amount of power.
If that truck were mine and wanted to keep the sbc, I'd do the following things w/o any internal mods...
-Clean up the tbi base with a dremel, or buy one already worked over
-tbi spacer, injector pod spacer, maybe some flow matched injectors
-Get a set of free flowing, smog headers and ypipe. A good flowing si/so muffler
*I ran edelbrock TES headers, they came with a ypipe.
-convert the fuel pressure regulator to adjustable - then bump the fuel pressure. Or you could buy one that is adjustable.
-Being its a 92, it would probably benefit from a billet distributor and an upgraded coil.
-bump the timing a few degrees
-4.3li torque converter
-bigger servo
-mail order chip from Wester's or PCMforless
Those mods wouldn't make it touch a gmt-400 xcab with a 6.0. But, it will be a nice running truck. And those mods are all do-able by someone who is mechanically inclined with a decent set of tools. And those mods would probably set you back less than $1,000.
Old 03-28-2012, 08:56 PM
  #23
matt92extcab's Avatar
I see people talking about servos what kind and where can I buy it
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
Aboss
07-09-2015 10:28 AM
davis28905
07-08-2015 03:20 AM
Quick Reply: cam swap on my 92 gmc tbi
