Cam Bearings too narrow
Old 02-11-2016, 06:54 AM
CF7GO's Avatar
Default Cam Bearings too narrow
Anybody see cam bearings like this? Why are they so much thinner than the stockers that came out?
Old 02-11-2016, 07:42 AM
Wolftrk99's Avatar
The bearings look like theyre wrong, stock bearings should be .765 i believe and there is another bearing ive seen listed that are something like .62x, dont know difference but i would think overtime the narrower bearing would cause issues....
Old 02-11-2016, 07:47 AM
CF7GO's Avatar
this one is .615"
Old 02-11-2016, 08:12 AM
Formerly ScreamingL
George C....'s Avatar
Different year motors had different size cam bearings
Old 02-11-2016, 08:16 AM
CF7GO's Avatar
From what I can see these are for '03 and older. This is a 2010 block.
Looks like I'll be calling the shop that put them in.
Old 02-11-2016, 12:01 PM
Wolftrk99's Avatar
You need the .765 bearings... Enginetech pn is cc433w only because i have a set sitting here.... If you want gm part numbers for updated coated bearings, i can get those here in a few.... There was a bulletin on the cam bearings
Old 02-11-2016, 12:18 PM
CF7GO's Avatar
Could I get that Number? What is the bulletin about?
Also reading 1 and 5 are different sizes??? That true?
Old 02-11-2016, 06:01 PM
Wolftrk99's Avatar
There are three different size bearings 2.345 1/5, 2.325 2/4, and 2.306 3 journals in the block cam journals are all the same ....the bulletin is about the updated coated cam bearings.... Get numbers here in a few minutes
Old 02-11-2016, 07:45 PM
Wolftrk99's Avatar
There ya go couldnt find it in mitchell dont have access to si at moment but interweb on my phone works too
Old 02-12-2016, 07:12 AM
CF7GO's Avatar
Thanks Man! I was told they are the DuraBond CH-25 but when I look those up they are supposed to be .775 wide. So I have no clue what is in this thing....
Quick Reply: Cam Bearings too narrow
