Buying a cam and need some advice
#31
^^^^ i agree, i think your first cam choice with some sort of stall would do better for a truck. those v3, v4 cams mentioned automatic cars in the description. are you planning on a complete rebuild or repair and replace?
check this out if you haven't yet
https://www.performancetrucks.net/fo...o-here-523548/
that is impressive. he has other video's of it in action but he put the flat tops in and had his heads intake valve size increased and ported them after. that is out of my skill set at the moment but totally changed my approach to my build gonna keep it simple with minimal down time. just to give you an idea and visual of what your trying to achieve in action.
That was a pretty awesome channel knuckles, good info in his videos. Not too sure if I will screw with the intake valves like he did although I wouldn't be opposed to cleaning and polishing the runners, who knows maybe I'll do that
#32
yeah, throwing all the goodies at it can get away from you in a hurry. just to find out that what you have at the end doesn't work as well as you wanted or thought and then have to end up replacing what you already have. better to approach thing's with an open mind and see what work's and what doesn't. knowledge is good, chances are it has been done before. give yourself a plan b or c also if your plan a will not pan out. at the end of the day you wanna know when you turn the key it put's a smile on face and not anyone else's cause you have won't have to replace/ rebuild things twice.
