Blocks of foam under intake manifold
Old 02-27-2008, 11:21 PM
chevytruckguy's Avatar
Default Blocks of foam under intake manifold
I was installing my nitrous solenoids and plate last week and noticed there were blocks of foam under plastic intake manilfold in my truck. 06 silverado with a 4.8. Will it hurt anything to remove those blocks, or should I leave them alone? thanks in advance. By the way I also did the throttle body coolant bypass, will I have any issues with that?
Old 02-27-2008, 11:47 PM
High on diesel fumes
thunder550's Avatar
I'd leave them in there. They keep junk from getting under the intake manifold.
Old 02-28-2008, 07:01 AM
Nick™'s Avatar
agreed, junk also includes water entry is minimized, water getting down to the knock sensors is a primary cause of their failure.
Old 02-28-2008, 07:12 AM
krambo's Avatar
Amen.
Old 02-28-2008, 08:20 AM
Their primary design was like a noise baffle, GM said. But they do serve a purpose in protecting from debris. But without them it's almost like an Air Gap Manifold but I'd safely say you'd never notice a power gain from removing them, probably a little more blabber at WOT.
Old 02-28-2008, 11:25 AM
Thanks for the help.
byrne_06
04-29-2017 02:19 PM
OHsixLS3
12-27-2016 09:30 AM
USMCvet0311
09-30-2015 10:34 AM
Hmguyton
07-07-2015 03:29 PM
Black-Syde
07-06-2015 02:12 PM
Quick Reply: Blocks of foam under intake manifold
