A bigger cam?
A bigger cam?
I can't believe I'm actually posting this, lol. I'm wondering if I went too small on the cam in my new 6.0. Now don't get me wrong, it runs absolutely awesome! I built for torque and it's got it, yet pulls like a mule all the way up. I'm 42 years old, and as fickle as it seems, I expected this cam to sound bigger. I wanted more lope. I certainly won't sacrifice performance for sound, but I'd love more chop. This cam does sound pretty good with some chop to it, but I'd just like more.
Step back for a minute and forget what cam I have in my truck. What cam would you recommend for my setup? Bottom and mid-range torque trump top end power, but I've got far more than I can harness now. Could I keep a similiar powerband, but get a bigger sound with more chop? All the important specs are in my sig.
IMO you could have gone a little bigger on the cam. for my 6.0 im debating between either a 224/228 or a 228r either on a 110 or 112 lsa. you might change your powerband a little bit by dropping the lsa to get more chop but you should still be good for what you want to get out of it.
PT's Slowest Truck
I think that you have the right specs for what you're describing as your goals...as you know, there's a give and take. That lopey sound that you hear is from overlap, and as overlap increases, driveability decreases. The 110 LSA that you referred to will bring the power on a little sooner, but the torque curve will not be as flat and will be more peaky. If you do decide to go bigger on the cam, I wouldn't go much more than a 224/22x on a 112 or you may lose that low end that you're looking for...just my .02.
FWIW, I've been known to be a little conservative on my cam selection, a lot of which has to do with my SBC background that I'm getting away from. I've changed my cam selection for my LQ9 numerous times...I already had a 216/224 in my possession which I sold, decided on almost the identical specs to your current cam, and now have my eyes set on a 224/228 .581/.588 112...who knows, by the time it comes together I may go bigger. Don't forget to match the converter and gears...
I'm probably already pushing the limit there. I'm at 650. Perhaps it's my exhaust setup hindering the sound I want. I've got some chop, but it just doesn't have as radical a sound I want.
On a positive note, I'm close to having this thing nearly as driveable as stock. That's something I'm not willing to give up. I want to be able to hand my wife the keys, and not have to worry about it dying in the middle of the intersection. I've spent FAR more time working on idle than anything else.
