ASP vs Powerbond vs stock pullies compare-o
11.0 Moderator
So i ordered a Powerbond pulley for my truck because no one had an ASP in stock. I then found an ASP for a good price so i ordered it. Took pics of all three pulleys and weighed them.
Weight of pulleys advantage ASP.
ASP 7.8 lbs
Stock 10.6 lbs
Powerbond 12.2 lbs
Quality of pullies advantage Powerbond.
Stock is a cast two piece that is pretty good quality. the power bond seriously looks like it should cost twice as much as the ASP. It just looks far better from a quality stand point. Also the Powerbond has very high lips so the belt will not get thrown like some have experienced on an ASP pulley. It also has a notch for a key and some cool timing marks on it like old school pulleys BUT you have to have an aftermarket crank or have your stock crank keyed for this to be of any use. The ASP also has a light weight aluminum center section which makes it lighter but if you remove and install your pulley A LOT of times, the aluminum could wear out over time and not be as tight on the crank as when it was new.
Ease of install avantage ASP.
To install an asp pulley you just put it on and tighten the crank bolt. The Powerbond, like the stock pulley, needs a longer bolt to first get the pulley on the crank or i use the head of an old crank bolt and an air hammer to get it on about a 1/2" or so before threading the crank bolt.
Conclusion, it's a toss up on these pulleys. so whichever one you find for cheaper is the one i would go with.
ASP 7.8 lbs
Stock 10.6 lbs
Powerbond 12.2 lbs
PT's Slowest Truck
I never realized how much smaller those pullies actually were, it's nice to see a side by side comparo, thanks for the write up
