Another lost torque / header thread
Old 07-20-2015, 10:07 PM
  #31
Formerly ScreamingL
George C....'s Avatar
You are preaching to a crowd that not one soul truly cares about your 350....You re better off on another site like GM fullsize
Old 07-20-2015, 10:13 PM
  #32
Resident Retard
BlackGMC's Avatar
lol...
Old 07-20-2015, 10:27 PM
  #33
Bumpers's Avatar
Definetly more left in the tuning .. once the tune is correct you will have a sotp increase from idle-
Old 07-20-2015, 10:31 PM
  #34
Fast355's Avatar
Keep thinking your LS is so much better for what he is looking for. Header sizing is not a hard concept to grasp and smaller primaries build torque in the lower rpm ranges even on a 6.0L. The 1 3/4" POS, non fitting Pacesetters I put on my Hemi didn't gain anything until I spun that engine to the moon with open exhaust. It was a bigger engine, with bigger valves, better flowing heads and a had more cam than a LS at 265/265 @ .006, 212/212 @ .050", .540/.540" lift, 114° LSA and 110° ICL. Pushed 5,300 lbs to a 13.59 @ 98.40 on 85 lb each P305/50R20s and 20" wheels. Took a 3,400 rpm converter, 4.56 gears, open exhaust and 6,800 rpm upshifts to do it though. I ditched the pacesetters and put stock SRT8 Jeep manifolds into 2.75" dual exhaust piping and ran within 0.08 seconds and 1 mph of the open header setup through cats and full exhaust. Torque on the street was phenominally better with the improved scavenging as well.
Old 07-20-2015, 10:37 PM
  #35
Formerly ScreamingL
Again no body cares ..........take some advice move on to GM fullsuse where they will listen to that nonsense you speak....all you're doing is wasting energy
Old 07-20-2015, 10:46 PM
  #36
Fast355's Avatar
I KNOW that I AM RIGHT when it comes to headers and primary size for a stock 4.8 and 5.3. Plenty of information out there on the subject if you take the time to look for it. Plenty of dyno test that show low-end torque loss with larger tubes with gains over peak torque and toward redline. Saw one test with up to 40 ft/lbs lost at 2,500 rpm by simply using too large of a header primary. Too small of a primary is less detrimental than too large of a primary. You are only talking about 294 and 323 cubic inches and heads that flow 240 cfm @ .050, not exactly highly tuned race engines. I have seen 550 hp 7,000 rpm 406 small blocks not gain anything up top from 1 7/8" headers compared to 1 3/4" and gain very little over 1 5/8" headers. The 1 5/8" headers made around 60 ft/lbs more torque though. Guess which setup ran faster in the car!!! The one with more torque! Not a hard concept to grasp. With the stock driveline the more average torque you make, the better the vehicle will run. Peak HP means NOTHING in a truck that is 5,000+ lbs, has the equivalent of a 3 speed transmission with an OD plastered on back, stock low stall torque converter and tall overall axle gearing.
Old 07-20-2015, 10:48 PM
  #37
Fast355's Avatar
The only thing you are doing is pushing the guy that is having a problem related to lack of scavenging away from the problem with his setup....LACK OF SCAVENGING at lower rpms due to too large of a header primary!!!!! Not everyone runs flat out, wide open throttle to the redline and has a heads/cammed engine with a loose converter and lower gears. Smaller primaries are ALOT better for part-throttle driving as well where exhaust volume and velocity is much lower.
Old 07-20-2015, 10:57 PM
  #38
Formerly ScreamingL
Again you're speaking nonsense, did you really wake up one day and say "hey let's see if I can get pt.net to drink the same **** I drank so we all believe the same nonsense"
Seriously telling ya this, gotten plenty of Pms in reference towards you and the nonsense....none are listening to you
Old 07-20-2015, 11:01 PM
  #39
TXsilverado's Avatar
I had a little long winded post made and decided to leave it alone. nobody around here is impressed with a mid 13 second truck. some guys have done that with STOCK 5.3 engines.
Old 07-20-2015, 11:04 PM
  #40
Formerly ScreamingL
Save your energy bro, trying to get thru to this fool is like trying to get an Obama supporter to not want 15$ hr minimum wage
Quick Reply: Another lost torque / header thread
