Alternator Wire Mod? - Page 8 - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 10-22-2007, 09:41 PM   #71
PT's Slowest Truck
budhayes3's Avatar
I'm running a 145amp alt and would like to upgrade the B+ wire from the red junction block to the alt. The thing is, I want it protected (like with a fuse or fusible link), but I want it to look factory. Does anyone know of some thicker guage fusible link that would work? Or a direct replacement that's larger guage?
budhayes3 is offline   Reply With Quote
Old 10-22-2007, 09:44 PM   #72
Ive got 4ga with battery connector eyelets soldered and crimped on each end of a foot of scoche amp wire works wonders (ive got a 145a too)
TylerCustoms is offline   Reply With Quote
Old 10-22-2007, 10:14 PM   #73
traveling mod
andrew383's Avatar
jknox- do you have a pic of your setup??
andrew383 is offline   Reply With Quote
Old 10-23-2007, 09:08 AM   #74
jknox's Avatar
Quote:
Not yet - I'll try to take a few in the next couple of days.
One other thing that made it a little easier - when my original battery finally bit the dust in July I bought a yellow-top to replace it. I've got the original factory wires still hooked up to the side posts and the new wiring goes to the tops. Scosche has some battery terminals that accept two 4ga and a single 8ga that Wal-mart sells. I use those for the post connections.
jknox is offline   Reply With Quote
Old 10-29-2007, 10:48 AM   #75
jknox's Avatar
Ok, here's a pair of pics. Basically what you see here are three ground wires - battery to alternator bracket, alternator bracket to body, and body back to battery.
Then there are two hot lines - alternator to the new mega fuse, and fuse back to battery (which parallels the existing stock wire). I did away with the original wire from the alternator to the red box.
The other cables on the hot post are for the audio setup. Also you can see the 60A maxi-fuse I added to run the efans off of (using the spare maxi location closest to the front of the vehicle.
Does this help any?
Old 10-29-2007, 11:03 AM   #76
lady3bglover's Avatar
Quote:
Originally Posted by exhappen View Post
Why do you guys add the wiring in versus replacing it? I want to put a larger guage from the alternator to the red box to the battery. And not have it look like crap.
I agree. Keep the view clean. Just upgrade the wire. I recently too replaced to the 130 from the 105, and I am completely satisfied. I was getting a little more concerned when I knew the reserve in my battery was being compromised.
lady3bglover is offline   Reply With Quote
Old 10-29-2007, 11:29 AM   #77
jknox's Avatar
Bear in mind that the box cover hides 99% of the crap. I'm also planning on replacing the red battery cables that I originally used with more welding cable. Once that's done the only part that should look non-oem will be the top-post terminals themselves.
Thread Thread Starter Forum Replies Last Post
2006 RCSB 4x4 V6 to V8 LQ9 Cammed Manual 5 Speed Swap ARC GMT 800 & Older GM General Discussion 53 07-02-2016 11:08 PM
Mild cam??? Cowboy Tom GM Engine & Exhaust Performance 6 09-05-2015 05:29 PM
Electrical Issues Idryfly5 GMT 900 Trucks General Discussion 1 09-02-2015 01:06 AM
2015 Silverado Chrome Door Handle to Black Door Handles RoidedSS SHOW & SHINE DISCUSSION 0 08-11-2015 12:51 PM
Tags
03, 1500, alternator, awg, battery, chevy, fuse, hemi, mega, mod, silverado, ss, stock, welding, wire
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
