After 4l80e swap motors misfiring NEED HELP
Old 04-17-2015, 10:29 AM
Registered User
speedchain's Avatar
Default After 4l80e swap motors misfiring NEED HELP
I did a 4l80e swap on my 01 ecsb last night and when I got it all done I took it for a test drive and the motor started missing and losing power bout every second on and off and it only does it when I'm gaining speed whether it's 1\2 throttle or at wot. Once I set cruise it runs good and it idles good as well. And when I'm parked and Rev it it sounds good as well. Any idea what it could be?
Trying to go to the track 2nite so really hoping to get this resolved asap
Old 04-17-2015, 01:01 PM
GM1697's Avatar
did you tune for the 80?
Old 04-17-2015, 03:03 PM
Registered User
speedchain's Avatar
Yes I did
Old 04-17-2015, 03:24 PM
Resident Retard
BlackGMC's Avatar
Did you pinch the harness on the back of the motor between the engine and tranny?
Old 04-17-2015, 03:51 PM
03sierraslt's Avatar
This is a very good possibility.
Old 04-17-2015, 09:30 PM
Registered User
speedchain's Avatar
No wires got pinched I have had the ground wire between there once so I made sure that didn't happen again
Old 04-17-2015, 10:57 PM
Resident Retard
BlackGMC's Avatar
did you remove your headers while doing the swap? If so did you remove the spark plugs prior, you might have messed one of them up.
Old 04-18-2015, 10:51 AM
01silvy's Avatar
^^^^^ if you did this and nicked the porcelain on the plugs or cracked it, it will misfire.
Old 05-18-2015, 04:52 PM
Registered User
speedchain's Avatar
Wel I think I found the problem couple days before I did the tranny swap I installed a walbro 450 fuel pump and due to my tbss intake swap I put a corvette filter on for the return and I guess it can't handle the big pump because the fuel pressure is like at 85 psi. So I guess it decided to go out at the same time I did the tranny swap making be think it was the trans.
So I think I'm gonna go without the corvette filter and just get a regulator.
Next question is there a non vacuum fpr that I could use or what would be the best way to fix the regulator problem?
Old 05-18-2015, 05:06 PM
Smaller fuel pump or a return fuel system.
Quick Reply: After 4l80e swap motors misfiring NEED HELP
