AFM 6.0 cam in LMG with dod delete?
Was throwing a motor together with some extra stuff lying around. Have an LMG 5.3 with DOD delete and afm delete and 317 heads. Have a brand new cam out of a gen 4 6.0. Started doing research and reading that the cam lobes are different on the afm cylinders. Is this a bad cam to use on a afm dod delete setup and cause running issues on the afm cylinders?
http://www.ls2.com/forums/showthread...al-Information
A from GMPP: AFM cylinders have slightly different grind ( a bit taller) to accomodate additional compliance of AFM parts --intent is lift event equivalence.
1.70 Exhaust Rocker Ratio
1.69 Intake Rocker Ratio
Lift:
@Cam @Valve
Exhaust: 0.282 0.479
Intake: 0.279 0.472
Cam Timing@0.004" Tappet Lift:
Open Close Adv. Duration
Exhaust: 71 BBDC 33 ATDC 284
Intake: 11 BTDC 91 ABDC 282
Cam Timing@0.050" Tappet Lift:
Open Close Duration
Exhaust: 40 BBDC 12 BTDC 208
Intake: 17 ATDC 37 ABDC 200
200/208 0.472 0.479
Further Cam Info just received:
* Camshaft Lobe Lift - Exhaust - Non Active Fuel Management Cylinders
7.17 mm
0.282 in
* Camshaft Lobe Lift - Exhaust - Active Fuel Management Cylinders
7.3 mm
0.287 in
* Camshaft Lobe Lift - Intake - Non Active Fuel Management Cylinders
7.08 mm
0.279 in
* Camshaft Lobe Lift - Intake - Active Fuel Management Cylinders
7.2 mm
0.283 in
* Valve Lift - Exhaust - Non Active Fuel Management
12.19 mm
0.480 in
* Valve Lift - Exhaust - Active Fuel Management
12.41 mm
0.489 in
* Valve Lift - Intake - Non Active Fuel Management
12.04 mm
0.474 in
* Valve Lift - Intake - Active Fuel Management
12.24 mm
0.488 in
Lift:
@Cam @Valve
Intake: 0.279 0.472
Open Close Duration
200/208 0.472 0.479
7.17 mm
0.282 in
7.3 mm
0.287 in
7.08 mm
0.279 in
7.2 mm
0.283 in
12.19 mm
0.480 in
12.41 mm
0.489 in
12.04 mm
0.474 in
12.24 mm
0.488 in
