Adding timing chain tensioner/ dampener to LM7?
Trial & Error is always an option, but would rather not waste money ya know? haha
If anyone has literally used a double roller timing set, stock timing cover, and this tensioner kit, with stock or Melling oil pump, on an LM7, I'd appreciate the input.
so the lm7 does not have the bolt holes for a tensioner? any pics of how this trick flow kit bolts up to a lm7 block? i was thinking i just needed the dampener but based on this thread looks like i need this kit too
_Zblee
_Zblee
If you go to summit website and click on download instructions or something similar, it shows you how to install it and torque spec for bolts and how to install it where.
It looks like the adapter goes on the outside of the cam thrust plate and replaces 3 of the 4 cam thrust plate bolts, then the factory plastic tensioner is pressed onto the adapter as it states in the instructions.
I'm just trying to figure out if double row chain set will still work with this, I ordered it anyways, I'll post once I find out.
