92 305/350 - setting the timing ? - How to ? - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 11-17-2009, 01:17 PM   #1
Default 92 305/350 - setting the timing ? - How to ?
so how is it done? My co-worker is talking about a primary wire that goes to the PCM that needs to be unplugged or something while it's being set?
How do you start? Timing light, and set to 0* and TDC, then what ?
Tootall is offline   Reply With Quote
Old 11-17-2009, 04:32 PM   #2
wow that sounds easy . . .
This is a bone stock truck
Old 11-18-2009, 05:13 PM   #3
blklime02's Avatar
would this work on a 90 model??? im swaping the distributer cap and rotor and was told that i needed to redo the timing......????
blklime02 is offline   Reply With Quote
Old 11-18-2009, 05:32 PM   #4
454navyss's Avatar
same thing works on a 90 model too
be sure to take mods into account, this didnt work well on my 454ss. i had to keep my timing at 12-14 with the advance unhooked (mods are in my sig) but for a stock engine 0 will work fine
454navyss is offline   Reply With Quote
Old 11-18-2009, 05:48 PM   #5
blklime02's Avatar
oh its stock...just a K&N filter...but wat if i later upgrade...have plans for headers and full exaust and chip......
Old 11-18-2009, 05:51 PM   #6
454navyss's Avatar
just bump your timing up a few degrees and see where it runs the best is what i did, some people know how to figure that stuff out but i dont
Old 11-18-2009, 07:27 PM   #7
PT's Slowest Truck
budhayes3's Avatar
Quote:
You don't need to touch the timing to do a cap and rotor, but you can play around with it if you wanted to try and squeak a few more degrees out and see if you pick up any power
budhayes3 is offline   Reply With Quote
Old 11-18-2009, 10:56 PM   #8
blklime02's Avatar
hell yea i wana get some more ponys from it!!! lol
but i go up on the degrees right?
Old 11-18-2009, 11:51 PM   #9
PT's Slowest Truck
budhayes3's Avatar
Yes, I'd try going up 2 degrees at a time until it pings then back it off...
Old 11-19-2009, 12:09 AM   #10
blklime02's Avatar
until it pings??
ive never done this befor wat is supose to ping?
wat is TOO much timing??
Thread Thread Starter Forum Replies Last Post
almost ready to dive into a low buck brake upgrade SLOPONY GMT 800 & Older GM General Discussion 20 10-18-2016 07:05 AM
Turbo 2007 NNBS Silverado RCSB chopperloco Trucks and SUV Classifieds 15 07-10-2016 11:45 PM
Finally in the 11s fastjweb Drag Racing 20 08-15-2015 11:47 AM
F/S: Innovate wideband - TBSS gauge pod -Ls2 injectors + more maxspeed05V GM Parts Classifieds 0 07-19-2015 08:08 PM
My Final Set up...what's your guess lo4x4 FORCED INDUCTION 4 07-05-2015 06:58 AM
Tags
1500, 1990, 305, 350, 454, 92, chevy, gmc, ignition, set, setting, silverado, ss, tbi, timing
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
