78mm throttle body on a 5.3 intake?
Old 07-23-2008, 01:34 PM
1Topgun's Avatar
Default 78mm throttle body on a 5.3 intake?
Will a LS1 78mm throttle body work on a '00 5.3 truck intake manifold?
I'm thinking about getting a ported 78mm TB when I change the engine out to a 5.7 long block, but use my 5.3 intake manifold to keep everything matched up on top. I don't want to go the pulley relocation route, etc. needed with an LS6 intake.
Would I see any gains over just using my stock TB from the 5.3?
Any experienced info or opinions would be appreciated. Thanks.
Mike
Old 07-23-2008, 02:05 PM
Wearin' da big hat
00ChevyScott's Avatar
the stock truck throttle body is 78mm. Just get it ported and polished
Old 07-23-2008, 02:45 PM
1Topgun's Avatar
I haven't had mine off to measure it, but I understood the stock 5.3 throttle body was 75mm. Are there any differences between the LS1 and cable drive truck throttle bodies?
Old 07-23-2008, 02:58 PM
High on diesel fumes
thunder550's Avatar
The throttle cam on the side is keyed differently. You'll have to relocate your throttle cables. Not worth the hassle IMO...they are either exactly the same size or close enough that you won't notice a difference.
Old 07-27-2008, 11:09 PM
LSX Mechanic
Damian's Avatar
It's not worth any HP between the two.
I port the cable and DBW TB's for $55 shipped. If you're interested feel free to PM me. There's a LOT of material that can be removed from the truck TB's for a nice throttle response gain.
jdb11386
12-03-2015 09:34 PM
Slammed96
07-27-2015 07:22 AM
fat tony157
07-16-2015 12:35 PM
jrplz
07-09-2015 12:07 AM
Gadgetized
07-07-2015 04:40 PM
Quick Reply: 78mm throttle body on a 5.3 intake?
