5.3L pinging problem
I just bought a 2006 tahoe which was a bank repo and we have no history. It appears stock but has a CIA and some sort of aftermarket muffler. Truck runs great but pings terribly under WOT after engine hits about 4k. Sounds like bb's being poured down intake. There are no codes, but Im thinking either it has a botch tune/programmer or Knock sensors are not working ot both? Anyone ever had this problem? I wouldn't think stock tune cld ping this bad even with no sensors?
I did a log and absolutely zero KR while it's pinging it's head off. It even pings at the hit of the throttle. Timing during WOT goes to about 30* @ .56 g/cyl and 4400 RPM but timing in high oct timing table is 24* at that value. Something somewhere is adding 6* of timing.. Appears that the IAT sensor is working, and coolant temp sensor is working Narrow band is 830 mV @WOT.
How many miles are on this thing? I've seen them before with excessive carbon buildup in the head. For what the Narrow bands are worth, it looks like it could use more fuel. You know how to tune so you know the obvious stuff. Look at the tune. Post up the tune.
A tune commanding 30deg at WO doesn't sound stock.
Thanks guys. I think the programming is stock is the prob. It's commanding 24deg but seeing 30. Something is going on but even at 30 it should not ping this bad id think. Tahoe has 120k miles on it. Yea prob have to buy a lic and tune it a little. Sucks that I can't ream it and clean it out, just pinging so bad it would end up blown up. Might just end up throwig a lq4 in the damn thing lol
What software do you tune with? 30 deg is a lot for a stock motor on 87.
On that note, I've seen a couple motors not show KR and ping. They would show KR and then zero out before they would ping.
Run some top end cleaner through it. A stock tune should not command that much timing at WO even with 6 deg being added.
