5.3 into 97 sierra swap
Hello all. i recently got my hands on a 5.3 out of an 01 02 suburban and am in the process of tearing down. My plan is to rebuild it and get a little more power out of it maybe 350-400hp range when im done. im looking at doing a cam swap ie from research possibly a 212/218 comp cam as well as a few other mods. wondered what mods would be recommended to do it right and cheap as im on a lower budget. Ive got a 97 gmc sierra with the 4.3 and a 5 speed that i was planning on putting it in. wasnt for sure if the 5 speed would bolt up to the newer 5.3 or not and if that would cause any computer probs. thanks
Your trans will bolt up to the 5.3. People will tell you it isn't strong enough but i had a 383 with 450 ft lbs of torque connected to it with no problems. I now have a 5.3, prc 2.5 5.3 heads, 222/226 cam, LT headers and a 2008 truck intake with the same 5 speed. You will have to get the right flywheel sachs nfw1050. You will also need a new clutch setup.
Custm2500's Rude Friend
01 02 suburban should have a mechanical drive by cable mechanical throttle body.
If it had a Autoride suspension it may have the Drive by Wire with an Electric motor that controls it.
In a 97 you will want to use a 411PCM and a mechanical Throttle body any way.
You can switch the throttle body no issue there. you will have to modify the harness though for the 2 plugs needed for the TPS sensor and IAC valve. Electric TB has 1 large plug. instead of 2 small plugs.
Of course you can always get a correct harness as well.
12200411 is the service number on the computer that most people use for this swap.
It's often referred to as 411 or 0411.
With that PCM and the harness to match, (I don't know what PCM or harness you Have) You can make everything function in your current vehicle including the gauges.
All you would need to do is use a cable throttle body instead of an electric throttle body.
If you search "LS Swap GMT400" on google there is alot of coverage of how to do the swap and the wiring.
