5.3 to 6.0 question
Old 05-29-2016, 01:49 PM
Registered User
MXDAD140's Avatar
Got her together and back in the truck. She runs good but just doesn't feel peppy as the 5.3 did. Have not got it tuned yet but trying to decide now if it would be better to change the injectors over to the ones that came out of the 6.0. Thoughts anyone? Running the 12480033 cam with 243 heads.
Old 05-29-2016, 03:55 PM
Wolftrk99's Avatar
What lbhr are the 6.0 injectors vs the ones you have now, and that cam is more likely than not going to need a tune... What converter did you end up with???
Old 05-29-2016, 04:34 PM
Registered User
MXDAD140's Avatar
Kept the 4L60 convertor. With the 5.3 crank she bolted right up. 6.0 injectors are from a 2000 2500HD truck. Don't know the flow numbers on them.
Old 05-29-2016, 06:01 PM
Wolftrk99's Avatar
Sure a google search of the part number will tell you about the injectors!!
Old 05-29-2016, 06:49 PM
10 Second Club
As far as I have seen, 4.8/5.3/6.0 all use the same injectors. (24#/hr most years)
It should feel much better after a tune. When I went from 5.3 to 6.0 in my old truck - it felt "soggy" for lack of a better term - down low. But as speed increased, you could tell it wanted to go. After a quick street tune, whole different animal.
Old 05-29-2016, 11:43 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Needs a tune! The factory 5.3 tune is specific to that displacement.
If you look at a factory tune you will see a spot where is ask for the Displacement for its calculations.
Old 05-30-2016, 12:53 AM
Wolftrk99's Avatar
In hp tuners it under the general tab under engine, asks for nimber of cylinders then the displacemnt per cylinder!
Strongsperformance
04-17-2016 09:04 AM
procelll
04-01-2016 06:34 PM
chaosz71
03-29-2016 05:21 AM
726.0chevelle
03-28-2016 09:45 PM
Luis3701
03-03-2016 06:54 PM
Quick Reply: 5.3 to 6.0 question
