5.3 to 6.0
Try to stick to a 2001-2006 6.0. The early lq4s had a longer crank due to being mated to the 4l80e. They upgraded the connecting rods in 2005. Keep in mind that the 2003+ engines are Drive by wire and use an electronic throttle body. You'll have to slap the intake you have know on it.
Everything should swap over, we did the same thing on my brothers 2000 Silverado. You can drive it without a tune but you will need one eventually. Just as a heads up, our tuner told us that the stock 5.3 injectors were close to maxed out, so you may want to upgrade.
