4l60e with transgo programing shift kit
Old 10-28-2014, 10:50 PM
danny23's Avatar
Default 4l60e with transgo programing shift kit
How much engine hp can a 4l60e can handle.with a transgo shift kit and corvette servo is for 5.3 with tr220 cam and a circle d stall 3200 rpm
Old 10-28-2014, 11:36 PM
FFDP's Avatar
I'm just going to say not alot. With nothing else done you are always on borrowed time, it might last a few thousand miles or less, maybe longer who knows. All depends on how you drive it I guess.
They arent strong enough behind a stock motor, just put it that way.
Old 10-29-2014, 09:02 PM
danny23's Avatar
I was just trying to see how much it will hold i guy who sells these kits told me it will hold around 420 crank hp was not sure my tranny has 70k thats why i was asking plus im aroun 390-400 hp really close,, and with these low miles dont want to damage the tranny either,, i know the 80e is way better
Old 10-31-2014, 08:44 AM
robm-951's Avatar
I put one in a cat-back only truck at 100k with a custom diablo tune at the time without any issues. I think I put something like 20k on the truck before selling it and it was still doing fine I did have to put in a new separator plate not included with the kit because one of the check ***** was stuck in the old one. So you might want to pick one of those up as well if you decide to install
Old 10-31-2014, 06:06 PM
danny23's Avatar
But your truck was pretty much stock right?
Old 10-31-2014, 09:02 PM
Turbo09's Avatar
It will be fine, mine is holding up with just vette servos and allot more power it has been for 50k.
Unless you constantly smash the throttle and downshift at wide open throttle it should be fine.
I use mine for towing and sled pulling and DD abuse, just have the line pressure bumped up and down shift manually before mashing the throttle and it will live a happy life.
Old 11-02-2014, 01:40 AM
James B.'s Avatar
If you want that trans to last a while set up the shifts to be soft. A 4L60-E absolutely cannot handle hard shifts. A few failure-prone parts are the sun shell, the sprag, the input shaft, and the notches in the drum that hold the retaining ring. It's been a while since I've done a TransGo kit in a 4L60-E, they used to have 1-3 washers that served as spacers under the band servo. I wouldn't use more than 1.
So, in summary - it's best in these to not try to prolong the life of the consumable parts (clutch plates and band) by making them shift fast because that will kill the weak hard parts.
Old 11-02-2014, 06:47 PM
danny23's Avatar
Yea i remember reading something im a article about how to install tge transgo and drilling some extra holes and something about washers just dont remember where it was a step by step on how to install this kit ,,,, do you know.of a good rebuilt kit along with the transgo kit to make a good strong tranny
Old 11-02-2014, 10:31 PM
10 Second Truck Club
RS/SS 4.8's Avatar
It all depends on luck i guess. My 4l60 is bone stock with raised line pressure and chirps 1-2 at any throttle above 50% with a 3200 stall converter. The motors a 4.8 with the tsp 220/581/112 and its been doing fine for the last 60k miles. Its currently got 114k on the truck and still chirps the heavy *** 20s on it.
Old 11-03-2014, 04:40 PM
WICK3DxGATA's Avatar
i have 99 ecsb z71 5.3 on 33's cammed with a tr220 and a circle d 3000, total the trans has 202xxx miles the last 20k have been with the cam and converter installed. the trans is completely stock and the only problem ive had is the TCC solenoid went out. And i beat on the truck daily driving it.
Quick Reply: 4l60e with transgo programing shift kit
