4.8 swap to 6.2, some help!
Just order a complete bearing set with the ring and pinion set and Truetrac. And have a reputable shop do the whole job. I ordered everything at 4WheelParts. I'm lucky since I have a location locally but their good to deal with online too.
Can you talk with my in my number to get more info ? My number is 1(786)719-9390. Thanks.
Ring and pinion are the gears themselves, the spider gears are inside the differential carrier and turn the axles with the ring gear, the carrier beatings on on the sides of the carrier under the caps, axle bearings are at end of the axle tubes pinion bearings inner and out are on pinion gear shaft, which the pinion yoke attaches to....which attaches to the drive shaft through the u joint....
You wont need worry about spider gears if you're getting a TrueTrac. That's an entire new differential so it'll replace all of that. the ring gear just gets bolted to it and in it goes.
You'll love the trutrac, best LS rear for the money. I have had them in 3 other vehicles as well as my 07 Tahoe.
You'll need a master rebuild kit for a GM 10 bolt, make sure you find one specific to your year. I think they vary in years so you if you buy one not specific you may be missing some parts.
I'd also find a 4x4 shop to do the work.
Good luck and good luck with the swap to, I'm looking to do the same with my Tahoe, 5.3 to 6.0 bored out to a 6.2
Miami right? I'm pretty sure there is a 4Wheelparts there. Unless you know someone you really trust. You may pay more but its been my expereience, you'll get good sevice and quality work.
