2007 GMC 5.3L broken piston skirt.
With 100K miles on the truck and an engine ticking noise for 500 miles or so, I thought maybe one of the AFM lifters on this truck had dropped. I began to tear into it. After pulling the lifter trays I found a nickle sized piece of a piston skirt wedged under the tray. Knowing I had to dig deeper I pulled the oil pan and found the #2 skirt with a nice chunk broken out. After seeing that I went ahead and pulled all the pistons. As expected compression rings looked pretty good but several oil rings were pretty locked up with carbon.
I plan to do an AFM delete, 212 218 Comp Cam, Valve seals, LS6 springs, new oil pump, timing sprockets and chain with LS1 damper, pistons, rod bearings and headers.
I'm just wondering if any of you have been here before?
I should have mentioned that the motor internally is very clean with no sludge at all. All bearing surfaces look very good. No other problem found except for the piston on the photo. All cylinders checked with a bore gauge and well within GM specs for a 5.3. I found a max of 3 tenths taper and that wasn't even the #2 hole. All original cross hatching clearly visible.
swathdiver (06-15-2020)
My dad cuts hair and one of his customers is the GMC dealership manager in a nearby town. He told us that the 2007 has oil consumption issues and a broken piston skirt can be the result of this. Now I can report that keeping oil in it is a constant battle but I have never seen the oil light come on but often it is a quart low. So who knows?
Broken piston skirt
Attachment 92093
Attachment 92093
polishing a turd on my dime....
zblee
63
06-10-2023 01:25 PM
GXPJAY
02-13-2022 08:15 AM
05GMC4.8
08-07-2015 09:55 PM
