2000 chevy straight pipe? - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 04-17-2010, 09:07 PM   #1
Default 2000 chevy straight pipe?
I've been told that if I want to do away with the cats on my 2000 5.3 chevy,,that it will mess with the sensors and it wont run good. Has anyone here done that? I have a gibson exhaust,,just from the cat back...
I'm really just looking for more power, and Oklahoma doesnt do any vehicle inspections anymore!
Reloy is offline   Reply With Quote
Old 04-17-2010, 09:09 PM   #2
13 Second Truck Club
You won't gain any power from removing the cats on an essentially stock setup.
DV2000NJ is offline   Reply With Quote
Old 04-17-2010, 09:43 PM   #3
why no power gains? It has the Wheatley tuning
Old 04-17-2010, 10:10 PM   #4
You will gain 1-3hp by removing the cats on a stock setup. Not worth it and the trouble it will cause because you don't have the tune set to compensate for it and will require a retune.
HoveyBayou is offline   Reply With Quote
Old 04-20-2010, 09:08 AM   #5
would it be worth getting high flow cats? Mainly looking for better sound.. Have dual flowmasters on it now, 5.3
02ws677 is offline   Reply With Quote
Old 04-20-2010, 09:28 AM   #6
Sc00by's Avatar
From what I have heard its not worth just removing the cats. If your going to go through all that trouble (including re-tuning your truck to run with out cats) its worth more installing a good set of long tube headers a new y pipe (if your going to still use the single tube exhaust) and then having it tuned. Way more gains.
Sc00by is offline   Reply With Quote
Old 04-20-2010, 09:36 AM   #7
Evil Eric's Avatar
like scoob said, the only reason u should remove the casts is if you are installing long tubes. the only other reason i would cut off cats without any other exhaust mods would be a clogged converter. The gains are just not there.
Evil Eric is offline   Reply With Quote
Old 06-09-2010, 04:03 PM   #8
ok, thanks for the input. This summer its getting a cam and headers,, so maybe then different exhaust setup,, We'll see.
Thread Thread Starter Forum Replies Last Post
2000 Silverado fixed seat question Shtbox GMT 800 & Older GM General Discussion 2 08-02-2015 11:52 PM
03 ECSB Custom T56 Swap Ketis Trucks and SUV Classifieds 6 07-23-2015 01:37 PM
Need help - Stumble at first cold start, dealer can't find anything wrong Mossyoakglock GMT 900 Trucks General Discussion 0 07-17-2015 09:30 AM
Isky Turbo Cam, NW 92mm TB, 5" exhaust cutout Atomic GM Parts Classifieds 9 07-11-2015 04:51 PM
Tags
2000, 53, cat, cats, chevy, code, legal, pipe, pipes, removing, run, silverado, straight
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
