What Size Injectors?
Old 07-30-2007, 07:43 AM
10 Second Club
WAHUSKER's Avatar
Default What Size Injectors?
I just installed a 6.0L into my Avalanche & I completely forgot about replacing the fuel injectors. I'm pretty sure the ones from my 5.3L won't be enough, especially since it has stage 2 heads & a Lingenfelter cam. What are you guys using? Would stock 6.0L inj's be enough? Who sells them on here?
Mark
Old 07-30-2007, 07:49 AM
truckmann's Avatar
I think some 8.1L injectors will be enough (36# at truck fuel pressure) for N/A. Nelsons has them or ebay.
If you want a little extra injector the 8.1 Marine injectors are rated for 42# and are also a direct fit.
Old 07-30-2007, 09:31 AM
Tootall's Avatar
Originally Posted by WAHUSKER
. . . Would stock 6.0L inj's be enough? Who sells them on here?
4.8, 5.3, 6.0 are all the same size
Old 07-30-2007, 10:55 AM
zippy's Avatar
You need to see if your truck had the flex fuel 5.3L in it. If it did, you have more than enough injector. If not, find some L18 or marine 8.1L injectors.
Old 07-30-2007, 12:52 PM
truckmann's Avatar
Was flexfuel available on an 03 model???
Old 07-30-2007, 01:30 PM
zippy's Avatar
It was available in 03', I'm just not sure if it was available on the Avalanche or not.
Old 07-30-2007, 03:43 PM
10 Second Club
WAHUSKER's Avatar
So that could mean they'll be OK. But if they are only 28s, then I doubt it. The 6.6L in my TA before the blower was undernourished with 28s & perfect with 42s....looks like the Delphi 42s that Nelson sells might be the answer. Thanks all!
Old 07-30-2007, 04:37 PM
ridnlow's Avatar
Im running 8.1 truck injectors 31lb's.. I usually see 65-70% duty cycle..
Old 07-30-2007, 04:40 PM
zippy's Avatar
Personally that's probably what I'd go with. They idle like a stock injector and you won't run out of injector with them.
Old 07-30-2007, 06:48 PM
truckmann's Avatar
If the price isn't a problem I think the 42's are the best choice wish I could afford some.
Stainless Works
13
11-05-2015 03:31 PM
WICK3DxGATA
08-31-2015 07:21 AM
maxspeed05V
08-12-2015 06:29 PM
FlowmasterMufflers
07-30-2015 05:03 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: What Size Injectors?
