Vibration under acceleration after 80E swap
Resident Retard
OP sorry to derail your thread.
Depending on which year/kind
4l80
4L80EGM Automatic Transmissions | 4L80 | 4L85E | Chevy Automatic Transmissions
4L60
4L60 GM Automatic Transmissions | 4L60 Chevy Automatic Transmissions
4l80
4L80E/4L85E 1991-Later (bellhousing pattern - Chevrolet) Std. 2wd Overall Length 32 11/16 inches
Bellhousing Height 20 inches
HD 2wd Overall Length 31 15/16 inches
HD long Overall Length 33 inches
4 X 4 Overall Length 29 inches
4L60
4L60E/4L65E 1996-Later (bellhousing pattern Chevrolet/removable)
All except Corvette and LS1/LS2
Overall Length 30 3â„4â€
Bellhousing Height 18 1â„4â€
LS1/LS2-style (1998-later)
Overall Length 31 5/32 inches
Bellhousing Height 18.25 inches
I measured the angles of the first driveshaft shaft and the trans. The trans points towards the ground at about 7-8 deg, and the first driveshaft is roughly level. So the working angle of the first u-joint is 7-8 deg. Could be wrong but this seems way too high. Looking at the link below, I should be aiming for 1-1.5 deg at the trans. Correcting this is probably a good place to start.
I can shim up the trans mount, but only to a certain degree because of exhaust-to-floorboard clearances. I'm also using the Belltech carrier bearing relocation kit, which moves the center support bearing up, this could be making things worse, but it has virtually no room for adjustment.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
What is the pinon angle on the rear end?? Generally speaking you want the pinon angle and transmission angles equal for daily driving and you want the pinon angle -2/4* less for drag racing so that.
LESS is better from an efficiency stand point.
Why is that?
From what I can gather, the angles of the components themselves (trans, pinion, shafts) doesn't matter. The angles between them are what matters since that determines the working angle of the u-joints.
I called spicer/dana and they said that the angles of the pinion and trans should be within 1 deg of eachother, and the u-joints should have no more than 3 deg of operating angle. This goes against what is said in the link I posted above, which says to make the angle of the pinion equal to the angle of the first shaft.
I really hate driveshafts and angles.
