Vibration at 60mph, 4l80e swap, tried everything
#21
Rear looks good, but the front almost looks like it could come up some. Then again pics can very easily be deceiving. Have you measured the angle that the output of the trans is at and the rear differential as well?
#22
Were your tires "road force" balanced?
If not,
Find someone with a Hunter GSP 9700 balancing machine and ask them to road force balance them.
If it takes more tha 3/4 of an ounce to balance it out, have them break the bead on the tire and rotate it 180 degrees.
If it sat long, you could have a nasty flat spot in your tires.
If not,
#23
If not,
If not,
#24
It uses a wheel that applies force to the rim/tire setup.
Wheel & Tire Balancer | Road Force Touch® Wheel Balancing Machine | Hunter Engineering
Locate a balancer near you:
http://www.hunter.com/gsp9700
#25
It most certainly will catch them. That's the great thing about the GSP 9700 balancers.
GSP9700 Locator
GSP9700 Locator
Oh, and here is a diagram of measurements. I'm probably at 2 degrees at the transfer case now and about the same at the pinion.
A CV (double cardan) driveshaft would take care of any problems, right?
#27
I ran it up to 65 today, let off the gas and coasted. Vibration while under power and costing. That's about the same test as in neutral right?
If not I'll have a chance again tomorrow night.
#29
