THE Tru-Cool 40K GVW Transmission Cooler Install Thread
#242
Man Motor club
1 Post
A few times on this thread folks have mentioned a NAPA fitting that supposedly screws into the cooler and connects directly to the GM line.
I got this fitting and I am fairly confused… the fitting from NAPA has a 5/8 NPT end on it… NOT inverted flare…. so I don't see why people are recommending this fitting… am I missing something?
Thanks!!
Thanks!!
#243
the fitting is to screw into the cooler. the other end is where the stock cooler lines go if you already have a cooler. if yours just goes to the radiator then you may not need that fitting as you have to plumb the lines how ever you want.
#245
I want to thank you for the detailed images you put into this post. I have a 2005 with a Radix also and wanted to see if my HX and the 40k would fit and your aerial photo angles was a true blessing for me to find.
I have a Mercado Racing HX thats a little thicker than the Magnuson OE HX and was worried.
I ordered my 40k today.
Tell us how your temps did after the install? Is you radiator still in the mix?
How is the truck doing?
#246
My 05 With Intercooler Install Went Well
Transbuilderguy is building me a Level 4.5 and he prescribed the 40k.
So on Doctors orders I made my own custom mounts with the lower one integrating my Mercado Racing intercooler.
I bypassed my radiator and used one of those lines in the process.
I used a small tubing bender and it worked out well allowing me to use the OE line support and routing hole.
Swagelok fittings and the Doorman 800-605 push to connect inlets in the cooler.
The space between coolers is 5/8".
Edit: Forgot to say thanks to all who posted in this very useful sticky thread.
The intercooler hose you see draped out has a protective wrap because of close proximity to bumper mounting hardware.
I made an additional bend in the OE line taken from the radiator that worked out well for fit and routing.
There is 5/8" clearance between the HX and the Tru Cool. Since the photo was taken I adjusted for proper clearance between the Tru Cool and HX top bracket.
One of the lower HX mounts.
This how I routed to the bypassed line. The rubber you see is a protective sleeve made from a section of the hose Tru Cool supplied.
I razor split it in a spiral and put it over the line. It clears even with the sleeve but runs in close proximity to the frame & cross member.
Ready for the grille.
#248
Thanks, and Thanks for the great transmission and recommendation to install the TruCool 40k.
The report on the TC40k cooler performance is a major difference even though it sits behind a water to air heat exchanger.
In 90+ temps I muscle to work 30 minutes on interstate and then city drive 10 minutes to the parking lot where it idles 5 minutes before I get out.
With the OE cooler It got up to 210°F once. Now it does not break 170°F. And if I let it idle until the fans shut off it comes down to the 150's.
Love It.
Love It.
#249
Installed my 40k this am with the EAD brackets, didnt have to cut the line on the right side just moved it over and it lined right up!!!! I did however mount the brackets backwards on the cooler... I also noticed my coolant temp was lower also.... Wish i had installed one years ago!!!
#250
