Transfer Case Leak
Transfer Case Leak
While I was changing my oil this weekend I noticed this Allen head bolt in the transfer case is leaking.
My truck is an 05 with the NP 246 autotrac transfer case.
I watched a YouTube video on a rebuild and it looks like this bolt goes through the case and holds a shift fork or bracket of some kind. Can I just drain the fluid, take the bolt out, and replace the seal or o-ring on it or does the transfer case need to come apart to do it right?
Not what I was wanting to hear, but I figured it'd probably need to come apart to do it right. It's got 212,000 miles on it so probably need to look into a full rebuild while its apart.
I do have a fix for the pump rub installed already. I did that myself a couple years ago when I had a howling noise. I thought it was the bearing for the rear output in the transfer case so I replace that and did the pump rub fix while I was in there. Turned out that wasn't really the problem. It ended up being the pinion bearing in my rear axle.
Ok, I've noticed this seems to be dripping pretty good now. I'm looking around at replacements or rebuilding it, but I'm having trouble deciding what I want to do with it.
Any suggestions on websites for parts or a rebuilt unit? I've found plenty, but I don't know how to tell the quality of the parts they sell. What should I be looking for to ensure I'm getting OEM quality parts?
Well, I was Keeping a close eye on the leak, but I wasn't expecting the pin to fall out completely. I came home from work one day and there was fluid dripping all over the underside of the truck and the pin was just gone.
I decided to take a chance and see if I could just put it back in. Found the pin on eBay for about $25 and picked up the autotrac fluid.
The pin went right back in with no trouble. I drained what fluid was left and it was pretty black.
I shifted through 4hi, 4lo, and 2wd a few times and it seems to shift fine. I didn't try driving in 4wd on pavement, but it's driving in 2wd.
I'm guessing from the way the fluid looked the clutches are burnt and 4wd drive may not actually work, but would there be any issues with the transfer case in 2wd?
I've got some jerking on downshifts and I'm thinking I notice some slipping when it used to spin the tires if I get on it hard from a stop. I'm just not sure if this could be from the transfer case or if I have a transmission issue too?
