Is this normal?????
Old 03-13-2007, 06:09 PM
mg53's Avatar
Default Is this normal?????
I installed my 4.10 ring and pinion into my 03 gmc this weekend and i hear that it is making a whining noise when i go between the speed of 45 and 55 mph, and thats it. No other time do i hear a noise! It is not loud and i have to cut the radio off and pick the windows up to hear it. I installed it to the spec that the company (motive gear) sent me. I set my backlash to .010 and set my pinion load to +/-2 just like they said. It also track like the picture showed in the diagram when i put the marking paint on the gear. Also i changed the bearings that the kit came with. I'm just wondering if this is normal and the noise will go away? I do not even have 100 miles on the gears yet, and i do not want to ruin them.
Old 03-14-2007, 03:52 PM
mg53's Avatar
Someone got to know something!
Old 03-14-2007, 04:46 PM
BLACKND's Avatar
Just my 2 cents, but I think even with the perfect install, your going to get a certain amount of whine from aftermarket gears. If you listen hard enough even some stock gears whine a bit. If its just a low whine, I wouldn't worry about it. My Richmond 3.90's whined something fierce in my old crew cab. I doubt the noise will go away completely, but will most likely soften up slightly.
If you are confident that you installed everything correctly.
Old 03-14-2007, 07:59 PM
06sierra5.3's Avatar
i noticed a whine in my stock 3.73 gears at certain speeds at a certain throttle. i used to be a tech for jaguar, every single car had a tiny whine at certain speeds with light throttle. its amazing what some old people can hear. anyway i think i a little whine will be normal expecially with aftermarket gears.
Old 03-14-2007, 08:09 PM
11 Second Truck Club
Cuerva's Avatar
It's normal and very common. You'll be ok.
Old 03-14-2007, 10:18 PM
negativeswitches's Avatar
wait untill they break in and then check your backlash
i say go back in after 5000 miles if it still bothers you then
otherwise
your fine
Old 03-14-2007, 10:37 PM
xsports33's Avatar
It's normal. Add some friction modifier to quite it down. It worked wonders on my 4.56s. Even though GM doesnt spec the additive, it doesn't hurt
Old 03-15-2007, 07:04 PM
mg53's Avatar
Alright, thanks for the comments! I feel alot better about my slight whine now. Just wanted to make sure that it was not something serious
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
10-04-2015 08:07 PM
02AWDAWSDenali
10-01-2015 05:08 PM
01silvy
09-26-2015 10:20 PM
TrickTurbo
09-23-2015 08:41 PM
Quick Reply: Is this normal?????
