Running slicks to the track
My local track is about 10miles from my house and rather than bringing a jack and swapping the rear wheels out I would like to just run slicks to the track. My question is what PSI should I run while driving there? Truck is about 5200lbs with me in it. And what PSI should I make my passes with (first time running slicks)?. I've heard, start at 20psi and work my way down until they hook how I want. Thanks for the responses!
Dicey... If they are ET streets, or some other type of DOT radial, then you will be fine. If they are a true all out slick, then I would just swap them at the track.
The tires are not beefy like a road tire, they won't deal well with road debris, or bumps and potholes. If its a clear, smooth road, you will probably be fine. Just steer clear of road hazards.
Id run 20 to 25 pounds there, then go down to 15 for a pass and go down from there. They should have a recommended psi rating. I think my hoosiers are 13-15psi, and I generally run there but lots of street racers have advised lower for non-prep stuff but they get dicey under about 12 pounds and I dont care for it.
8 Second Truck Club
Back in college I had a 1985 single cab short bed GMC with a warmed up 454 in it as my daily driver. Every Friday after work I haul *** down to discount tire and have them mount my slicks to my wheels. Then every Monday before work I'd go back and have them mount the street tires back up. So I would drive all weekend, every weekend, on slicks. The only time I didn't do it was if it was going to rain Friday Saturday and Sunday. So if rain was only in the forecast for one day of the weekend, I'd still do it. The reason I did this was because I did a lot of street racing and would hit the track Friday nights and I didn't have the money for a second set of Weld wheels. Anyway, I'd run them at 25 psi when cruising, air down when racing and then pump them back up. I had one of those **** air compressors that was powered by the cig lighter. Tons of fun and never had an issue, even when it rained. Those where the days.
Definitely not doing that. I'm just going to put them in at the track, save a little tread life.
