Ridetech Coil-overs Installed gmt-800
#254
Alright. Ridetech sent me a eyelet mount shock instead of the stud mount that I ordered. I have a couple options.
1. Send them back and have them send me the correct shocks.
2. Have them send me the stud mount and install it myself.
3. Use an adapter.
My question is this. Where can I find an adapter to install these tomorrow? I have called everywhere and most places have no idea what I am talking about. Also, if I do use an adapter will it cause the 4.1 shock to bottom out or put it out of the "sweet spot"? Unfortunately the guy I talked to at ride tech did not seem so tech savy. Im thinking I am just going to send them back. Any ideas?
3. Use an adapter.
#257
Do you have a 4wheelparts near you? They have them there. The stud mount is actually .3" longer than the eyelet so account for that too. I took a piece of square tubing and drilled 1/2" holes for shock bolts to use when mocking up my front end. I was very close 40% or so compression at the ride height I wanted. Other than that It's hard to say without putting it all together to find out.
#259
Ok boys. Im gathering info and from what I gather I need 4.1 shocks with 10" springs and about 950-1000# rate for my crew cab.
Few questions. Where do I order the 950-1000# springs as ride tech site dosent show them.
Also should I go with the Rq or the Hq series?
