Rear Shackle Bolt Removal - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 03-14-2006, 09:26 AM   #1
Default Rear Shackle Bolt Removal
Hello All, How do you get the 5"Shackle Bolt out when it's 3" From the Frame?
I want to put drop shackles, all would be easy except for this. Thanks in advance. Great Site!!!!!!
FastCrewCab4x4 is offline   Reply With Quote
Old 03-14-2006, 09:48 AM   #2
Fogle07's Avatar
if you have a hitch you have to drop it down so you can get the bottom bolt out then you can raise up the leaf springs enough to get the bolt out above the frame. its pretty simple to be honest with you.
Fogle07 is offline   Reply With Quote
Old 03-14-2006, 11:06 AM   #3
Default I ground the lip ...
dropping down from the bed out, then i ground part of the bolt flat (the washer part) then pulled it out over the frame..
Derek
virgils4.85spd is offline   Reply With Quote
Old 03-14-2006, 04:45 PM   #4
what Fogle said is the way I did it.I wouldnt suggest cutting anything where its not needed at all.
slowsierra is offline   Reply With Quote
Old 03-14-2006, 05:24 PM   #5
02BlueStepside's Avatar
Looks like you have a crew cab, if so like fogle said, shouldn't be that hard. Stepsides on the other hand are a little tough.
02BlueStepside is offline   Reply With Quote
Old 03-14-2006, 08:09 PM   #6
11 Second Truck Club
bluecajun5.3's Avatar
support the rear of the frame on jackstands to where the rear tires are almost off the ground. next place a jack under the rearend, loosen and take out the bottom bolt on each side(might have to jack the rearend to release the stress on the bolt) slide the bolts out. next jack up the rear end and push the leaf spring up by hand until the upper bolts clear the frame. then you can slide the upper ones out and reverse the procedure...
bluecajun5.3 is offline   Reply With Quote
Old 03-14-2006, 09:44 PM   #7
11 Second Club
ASkipper's Avatar
Look here with pics.
Put shackles on today
ASkipper is offline   Reply With Quote
Old 03-15-2006, 12:42 AM   #8
graystepside's Avatar
I had to cut mine because it is a pain in the *** on a stepside.
graystepside is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Need name for these wheels DarkhorSe_SS SHOW & SHINE DISCUSSION 14 08-20-2015 09:58 AM
Sould i get new shocks? LoneSStar GMT K2xx Trucks General Discussion 3 07-27-2015 10:27 PM
HELP! Shackle bolt seized to bushing sleeve! signguy62 GM Drivetrain & Suspension 7 07-27-2015 04:42 PM
Removing body Lift, Need bolts 08nali TOWING & OFFROAD PERFORMANCE 0 07-24-2015 12:39 AM
Tags
1970, 2003, 2006, 2500hd, bolt, camaro, chevy, gmc, rear, removal, removel, shackel, shackle, shakle, silverado, size
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
