Rear gear swap in a 4X4, do I change the front as well. - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 07-15-2010, 09:15 PM   #1
Default Rear gear swap in a 4X4, do I change the front as well.
I wan't to put 4.10's in my 06' ECSB Silverado 1500 Z71. A buddy of mine said I would have to change the front gears to match if I want to ever use my 4wd. I have 3.42's currently in the back and I don't know what up front. What do I really have to do? This is my first truck so I am lost with the 4wd stuff. It won't be cost effective if I have to change the front and rear gears.
Thanks guys.
Pray is offline   Reply With Quote
Old 07-15-2010, 09:30 PM   #2
PT's Slowest Truck
budhayes3's Avatar
Yes, the front and rear gears must be the same, so you will have to replace the fronts as well
budhayes3 is offline   Reply With Quote
Old 07-15-2010, 09:32 PM   #3
Well, that sucks. Thanks for the info. You just saved me a bunch of money. I will just use that money to build a bigger motor.
Old 07-15-2010, 11:04 PM   #4
fredkj3's Avatar
you dont have to as long as you never put it in 4wd except in mudd... hahahahah..
im jk dont do that... replace both or none
fredkj3 is offline   Reply With Quote
Old 07-17-2010, 01:03 PM   #5
Senior Member
Country Boy's Avatar
no, you do not have to do the front. Just remove the front D-shaft so you dont accidently put it in 4wd.
Country Boy is offline   Reply With Quote
Old 07-17-2010, 01:36 PM   #6
Banned
yeah you can remove the front driveshaft and you wont have to. But I hate having a 4x4 with no 4x4 capabilities.
I thought all 4x4's had some sort of G80-posi in them?
1LOW4X4 is offline   Reply With Quote
Old 07-17-2010, 05:50 PM   #7
Mine has 4.56s in the rear and 3.73s in the front with the driveshaft in. It is just temporary though. Only thing it will make it do is turn the ABS and BRAKE like on.
HoveyBayou is offline   Reply With Quote
Old 07-18-2010, 02:40 PM   #8
fredkj3's Avatar
yea it will work as long as you dont put it 4wd.... and also when the ABS light is on you wont have ABS...
Old 07-18-2010, 02:42 PM   #9
fredkj3's Avatar
that would be sweet to have if you could disengage the rear driveshaft.. and then you could have highway gears in front and towing/racing gears out back.. and swap between them
Old 07-18-2010, 08:00 PM   #10
Laid Back
Beatdown Z's Avatar
Quote:
Hmmm...twin-sticked NP205?
Beatdown Z is online now   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Steve-o-08's Silverado Build Thread, Take Three. Steve-O-08 PROJECTS GALLERY 214 Yesterday 04:45 PM
Regular Cab getting the 8L90? gnasty1521 GMT K2xx Trucks General Discussion 35 11-20-2015 12:42 AM
Gears and MPG Noah Burns GMT K2xx Trucks General Discussion 12 10-05-2015 07:46 AM
Best rear gear and brand USMCvet0311 GM Drivetrain & Suspension 13 08-14-2015 11:28 PM
NV246 Transfer case experts: Can these get "stuck" in 4wd? MileHighSierra GM Drivetrain & Suspension 5 07-23-2015 12:19 AM
Tags
06, 4wd, 4x4, back, change, changing, chevy, fornt, front, gear, gears, match, rear, silverado, swap
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
