qa1's coilover spring rate 2wd rcsb
yeah im going to get the weight and go from there but from what i seen online 600 or 650 should be ok for the qa1's thats what they list for big block cars with front end weight 2200 to 2400 lbs i'm guessing thats going to be around what the front weight of the truck is?
ridetech is a true coilover so there spring rates are not the same as the qa1's since there like a hybrid coilover
its called Pro Coil system # GS501 its a single adjustable shock/coil setup no mods needed for lowered 2wd trucks, not a ton of info for using them on the 99/06's only found a couple post that why i asked, 88/98 guys run them found a couple post on those trucks to
i planed to go ride tech but ran across these bnib to cheap to leave really so figure i'd try them
I have a gauge for that
Oh wow, so this whole time I thought you were talking about your 87, but you actually mean your 04?
If you didnt already have the shocks I would say if you can wait a couple weeks I have a design for a bolt in bracket kit that lets you use the normal heim mount instead of the tbar mount on the bottom of the 2wd trucks and reinforces that area and I am also a dealer for viking shocks so I could put a whole kit together for you.
yeah the 87 is long gone lol the 04 is the new project
i really wasn't financially ready to go coilover since i have the 6.2 at the machine shop and my z06 needs some work but like i said this pair came up (both for less then the cost of plain shocks) so i jumped on them since i really want to lower this truck any way and i already have a flip kit and the djm arms couple more things and i can get the stance right. my son has a 94 he might be interested in vikings
