Is this possible? My luck I'm assuming
Old 09-27-2015, 07:23 PM
13 Second Truck Club
trxmxzx's Avatar
Default Is this possible? My luck I'm assuming
So truck info is a 99 ecsb gmc 2wd (new style) anyhow I have a Flt lvl 5 -
I bought a yank sc3000 off a member here out of his ls2 gto
Well today I tore my truck apart thinking any 60/65/70e converter will be interchangeable -
The pilot pin on the converter won't go into my crank- so I have a gap between the wings of the converter to the flex plate. What did I miss?
I had them side by side looked good to go other than the sc3000 had rust on the pilot , maybe tolerance issue?
I was doing good to at 1:30 started tear down- stopped working on it at 4:45 with it all installed to find out the converter not sliding into crank fml - my luck sucks these days
Old 09-27-2015, 07:32 PM
03sierraslt's Avatar
Is your truck a 1500? Or 2500?
Old 09-27-2015, 07:41 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Did you physically measure the Pilot?
The rust could be causing an issue and the pilot may need to be polished to clean it up.
Old 09-27-2015, 09:25 PM
trxmxzx's Avatar
1500 sorry
Old 09-27-2015, 09:27 PM
trxmxzx's Avatar
No I did not measure- I thought about it but never heard of 60,65,70e being different.
Out of all the reading I've never seen the pilot being different sizes between gen 3 and 4
Old 09-28-2015, 09:04 PM
1FastBrick's Avatar
I don't think they are but you mentioned rust. I was afraid it would interfere with it going in.
Old 09-29-2015, 01:01 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
They are all the same. Clean up the pilot.
Old 09-29-2015, 06:18 AM
trxmxzx's Avatar
Yup I did yesterday after work- it was .020 thicker with the rust on it- I cleaned it off and it fit
Thanks for the help you all!
Old 09-29-2015, 07:42 AM
tgui's Avatar
Thanks for the help you!
Avalanche2002
11-30-2015 07:31 AM
zblee
11-11-2015 12:41 AM
Wolftrk99
10-02-2015 08:17 AM
murderedSS
09-27-2015 10:16 PM
FormulaZR
09-14-2015 05:23 PM
Quick Reply: Is this possible? My luck I'm assuming
