Pinion Angle
Pinion Angle
I dropped my 03 GMC (8' Long Bed) with a DJM 3" Lower A Arm in the front and 4" Shackle Relocation for the rear. Was fairly easy and was done over a weekend with with a friend, case of beer and a couple of cigars. Installed new shocks in all four corners and notched the frame in the rear with a DJM C notch for more suspension travel while hauling my car trailer.
I have a vibration at 75mph that gets progressively worse as you go faster. I measured the pinion angle and got 96 (maybe 97) on the rear end and 91 on the drive shaft.
So do I have -5 (or -6) as my pinion angle? Do I need to add shims under the forward part of the leaf spring to a -3 or -4 to get rid of that high speed vibration?
Thanks
Chad
Thanks
Chad
You want to measure the angle of both the transmission housing end and the pinion itself.
It's much easier to use 0 as the starting point. So like the transmission is pointing 3 degrees down and the pinion is pointing 8 degrees up as a reference. You'd then shim the pinion to come down to match the transmission angle or be withing 1-2 degrees depending on application.
I use an el cheapo angle gauge from the hardware store that works great.
