P1810 Trans Press. Switch Malfunction - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 08-12-2008, 08:44 AM   #1
Default P1810 Trans Press. Switch Malfunction
I pulled this code off of my 2003 Tahoe. Can anyone explain what this means? How to go about fixing it?
Could it be related to this problem I am still having?
Truck randomly dies!
Thanks,
sleek silverado is offline   Reply With Quote
Old 08-12-2008, 12:03 PM   #2
formerly 1BADC10 (12/14/2011)
95ImpSS's Avatar
Could be loose connection or faulty pressure switch (if that's the ONLY code actively reported).
Drain fluid / drop pan
Check connection on switch
Unplug & reseat connector
Reinstall pan
Add required amount of fluid (non-synthetic)
Clear code
Start vehicle & see if code reappears.
If code reappears, possible bad switch. Same procedure, but just replace switch (5 bolts securing in place).
*edit*
may/may not be worth it to replace switch since you'll already have the pan dropped. check on pricing.
95ImpSS is offline   Reply With Quote
Old 08-12-2008, 07:51 PM   #3
I changed the fluid and filter before I saw your post. The code is gone for now.
Old 08-12-2008, 08:25 PM   #4
95ImpSS's Avatar
hope it was just a fluke.
Old 10-07-2008, 03:45 PM   #5
11 Second Truck Club
Superado's Avatar
can too much fluid set this fault as well?
just curious...I got the same code today and I do need to drain out some fluid anyway...
Superado is offline   Reply With Quote
Old 10-07-2008, 04:53 PM   #6
Superado's Avatar
found this today...not sure what tranny you have:
Quote:
Condition/Concern:
A 4L80E may intermittently set DTC P1810 and exhibit harsh shifts. Freeze frame/ fail records may show the vehicle was in reverse and the P1810 set shortly after a cold start. The vehicle may also have not been started for an extended period of time.
Recommendation/Instructions:
This condition may be inadvertently induced by starting the vehicle and immediately shifting the transmission into a drive range or reverse. If the PCM does not see a PRND43 input from the transmission fluid pressure switch before the customer shifts into a drive range or reverse, the PCM will assume the TFP is malfunctioning because the PCM did receive a signal from the PRND43 switch and set the code P1810. This condition would occur more easily if the vehicle has not been started for an extended period of time because of torque converter drain back. DTC P1810 does not turn on the MIL the first failure, but does store the code and it commands maximum line pressure. The customer will probably notice only the harsh shift.
Currently, there is no fix for this condition. The dealer can advise the customer to start the vehicle and allow it to run for a few seconds before selecting reverse or selecting D4 before reverse.
Old 10-07-2008, 11:00 PM   #7
Interesting... I have a 4L60e in the Tahoe. The wife probably is the culprit for throwing it in gear as she starts the truck. I haven't seen a code since the original post.
Thread Thread Starter Forum Replies Last Post
4l60e won't shift Jakejack GM Drivetrain & Suspension 1 10-23-2015 01:33 AM
98 infiniti QX4 hit 266* dantheman1540 Foreign Performance Discussion 1 07-29-2015 05:45 PM
Feeler 2004 Turbo Silverado SS black6spdz Trucks and SUV Classifieds 9 07-16-2015 02:32 AM
Need 4l60e questions answered (Diff b/w Gen1 and Gen3) grantpo GM Drivetrain & Suspension 1 07-15-2015 01:21 PM
Evap solenoid and boost not playin well together Blackrat48 GM Engine & Exhaust Performance 5 07-12-2015 08:28 PM
Tags
2000, 2002, 2003, chevy, code, dakota, fix, malfunction, p1810, problem, service, silverado, switch, tahoe, trailblazer, typical
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
