Official 14 Bolt 9.5 SF Truck Thread
#31
Has anyone used a 14 bolt out of a Chevy express van? Will the factory disc brakes fit on this with the obvious modifications? I'm going with a custom set of bogarts anyways so wheel figment isn't an issue.
GM 14 BOLT REAR END WITH 3:73 GEARS AND 9.5'' RING GEARS. THIS WAS OUT OF A FULL SIZE CHEVY EXPRESS VAN 2000-2002.
OUTSIDE TO OUTSIDE OF SPRING PERCH IS ABOUT 53 1/2''
INSIDE TO INSIDE OF BACKING PLATE IS ABOUT 58 1/4''
George
George
#34
Thats to make a new brake mounting flange and weld it to the housing.
The 2500 and 1500HD 8 lug brakes have a different offset from the 1500 6 lug counterpart.
#35
Anyone have a part number for the axle shaft for the AXN for a 2006 Sierra. G80, GT5, JF3, possibly a less expensive replacement than the OEM part? have seal leakage with groove in axle shaft and the repair bearing wont let the clip fit back in place.
Thanks
Thanks
#36
They have the dimensions and can make you a pair of axles that is better than factory for 1/2 the price of just 1 axle from GM.
Last time I checked GM wanted around 550ish for just 1 axle.
#37
Thanks, I will give them a call Monday. Do you know the GM part number? I have been searching the diagrams and the one that appears to be the hybrid axle does not have a part number or description for the axle shaft.
Thanks again!!
Thanks again!!
#38
UPDATE! A guy on the performance trucks face book page posted this info for converting the NBS 8 lug 14 SF to 6 lug:
Yukon Axles - YGA-21425
03 Express 2500 6 lug Van Brake Rotors
Apparently the 6 lug van rotors will work with the existing parking brake, caliper, and caliper bracket.
#39
Did he post any pictures? I am not on FaceBook
walledition (11-08-2017)
